2014 V6 Engine Whine Noise???? - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 8 Old 09-30-2014, 08:14 PM Thread Starter
So I was driving home from work one night about a week ago, and I noticed a noise that resembled a "supercharger whine" as I shifted through the gears. It was very noticeable in first, second and slightly less in third gear, primarily through about 3K to 4K RPM on the tachometer.
Iíve got just shy of 3800 miles on my girl and donít recall hearing this noise up until this point. I took her into the dealer last Saturday to have an oil change just to get some fresh oil running through her veins since I was out of the engine break in period of 1400 miles and wasnít sure what kind of crud/debris might have settled in the oil. Once the dealer was finished, I hit the road. I didnít notice the whine sound any moreÖuntil Monday morning on the way to work.
Two things of note
1.) I was about a half quart low on oil a just after engine break in was complete, but topped it off. When I saw that I read the ownerís manual and it said that you may see a small amount of oil loss during the break in period. After topping off the oil it didnít seem to be losing any more.
2.) I saw a little bit of shimmery flakes (metal????) on my the rag after I wiped the dipstick when I checked the oilÖnot sure what this means, but Iím sure itís not good. They didnít mention finding anything during the oil change.
I had the dealer put on the service record that I found metal flake and oil level decrease and retained a hard copy for my records.
Has anyone experienced this? If so, what did the mechanic/dealer say was causing the whine?
Any info is greatly appreciated.
SilverSurfer is offline
post #2 of 8 Old 09-30-2014, 09:21 PM
S.Bretz's Avatar
A supercharge like whine is usually something that related to the accessories.
As far as metal falkes on the dipstick.... could it have been a coating on the dipstick that wiped off? some metal in the oil during break in can be normal...usually it decreases as the break-in sets in more. Monitor it and see how it goes. You do have 5yr/100k so don't be worried too much; if there is something catastrophically wrong it will show itself soon and you will get a new engine.
S.Bretz is offline
post #3 of 8 Old 10-09-2014, 02:50 PM
SC2150's Avatar
I agree w/S.Bretz. Tensioner pulley or idler pulley, alt, etc.
Metal I would pull the filter and carefully look in the pleats for any signs of gold or silver shine.
SC2150 is offline
post #4 of 8 Old 10-29-2014, 12:41 PM
V6's inherently have a whining noise, especially when the RPM's go up. Mine starts to get noticeably louder around 3200 rpm's.
sebian is offline
post #5 of 8 Old 10-30-2014, 11:03 AM
SC2150's Avatar
Timing chain issue sounds like this as well....
SC2150 is offline
post #6 of 8 Old 10-30-2014, 05:54 PM
bandier's Avatar
I have a 2010 2LT. Mine has the whine, and yes I've already replaced my timing chain. I just pretend I have a supercharger and run with it. I'm at 60K miles now. The whine became more apparent to me recently when I removed the plastic engine cover.
bandier is offline
post #7 of 8 Old 10-30-2014, 06:14 PM
83Hokie's Avatar
so do we have real chains or those dang belts?
83Hokie is offline
post #8 of 8 Old 11-01-2014, 08:12 AM
S.Bretz's Avatar
The v6 has chains....but they are prone to stretching.
S.Bretz is offline
