Header gaskets blow... - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 6 Old 11-07-2014, 09:42 AM Thread Starter
geonny04's Avatar
The gaskets are usually really good, so this is probably my fault. Looks like trimming them so they dont hit my headers was a bad idea.
Cleaned the header flanges up, nice as possible.
2011 2LT Coupe: BBK LT Headers w/ HF Cats. BBK CAI. AirAid TBS. Cat-Back Custom 3" Exhaust w/ Magnaflow Resonated X-Pipe and Pacesetter TFX Mufflers. Aggresive Trifecta 93 Octane Tune w/ Ghost Cam. 18" Advanti Summer Wheels and OEM 18" Stock Winter Wheels.
geonny04 is offline
post #2 of 6 Old 11-07-2014, 11:11 PM
S.Bretz's Avatar
Those gaskets usually work very well for a long time as long as the flanges are flat on the header.
..Have you put them on a belt sander to insure they are flat? Or you could go over them with a straight edge.
S.Bretz is offline
post #3 of 6 Old 11-08-2014, 09:51 AM Thread Starter
geonny04's Avatar
Yeah I was using the BBK gaskets. The OEM ones are a million times better. Sanded and check the flanges after. Theyre both perfect luckily, just had to sand off some of the crap left from the gaskets. New hardware and everything as far as bolts and bolt lock washers antiseize and what not.
geonny04 is offline
post #4 of 6 Old 11-08-2014, 09:54 AM
Here's where a light pass in a milling machine would come in handy....
patriotpa is online now
post #5 of 6 Old 11-08-2014, 10:17 AM Thread Starter
geonny04's Avatar
Ima swing by and use yours
geonny04 is offline
post #6 of 6 Old 11-08-2014, 11:25 AM
You'd have to buy me one 1st. Any machine shop will have one. It'd be a cheapto have done, and it's be within 0.0005" if the machinist is any good.
