ZL1 FUEL PUMP IN LLT/LFX CAMAROS - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 8 Old 09-24-2015, 05:12 AM Thread Starter
monty's Avatar
Does anyone know for sure if you can replace the stock in-tank fuel pump in a LLT/LFX Camaro with a ZL1 fuel pump? I know it fits perfectly in the tank but my question is, does the ECU or FUEL PUMP CONTROL MODULE need to re-programed for use in this application? OR, can you simply install the ZL1 pump with no program modifications?
monty is offline
post #2 of 8 Old 09-25-2015, 01:37 PM
SC2150's Avatar
Definitely plug and play. No issues.
SC2150 is offline
post #3 of 8 Old 09-27-2015, 06:01 AM Thread Starter
monty's Avatar
You are correct SC2150. I have had a few others with LFX's tell me they have already done the conversion with no issue. I ordered a ZL1 pump and will install it and verify LLT install. I'm preparing for the LFX engine conversion and I want to be sure I have more than enough fuel coming from the tank pump.
monty is offline
post #4 of 8 Old 10-01-2015, 08:30 AM Thread Starter
monty's Avatar
The part number for the ZL1 fuel pump is GM #19303293 or AC/DELCO # MU2101. Replaces GM# 19260557 & 19258436.
monty is offline
post #5 of 8 Old 10-10-2015, 03:14 PM Thread Starter
monty's Avatar
Installed ZL1 pump into my Twin Turbo LLT. Works perfectly with no modifications or programming. I cut a hole under the seat, as several others have done, to do the install and it was so darned easy. I'm a happy camper. Before on stock pump, I would see a reduction in fuel pressure (35 PSI) when I used the NOS. Not anymore with the new ZL1 pump, rock solid at 45 PSI! Thanks to everyone for information given to make this a success.
Name:	20151011_100004 (Large).jpg
ID:	47914   Click image for larger version
Name:	20151011_100946 (Large).jpg
monty is offline
post #6 of 8 Old 10-11-2015, 03:13 PM
83Hokie's Avatar
never would have thought of that ...
83Hokie is offline
post #7 of 8 Old 05-02-2018, 11:25 PM
How did you know where to cut the hole?
datsundave is offline
post #8 of 8 Old 05-03-2018, 12:02 AM
I think by looking at his posted pictures it should be very easy to find the exact spot.
