my new engine - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 27 Old 02-02-2009, 10:36 PM Thread Starter
camaro1's Avatar
my new engine
hello, i work at a GM dealer and here is my project, i have a 2ss auto trans ordered and here is my replacement engine built and waiting for its new home
LS3 stroker 415ci, 4" stroke crank, h-beam rods, mahle pistons, cnc ported LS3 heads with pac springs, comp cam,
long tube headers (my car has been chosen by a major header company to be the test car for their stainless long tubes and 3" x-pipe)
yank 3000rpm converter
hp tuners
engine is now complete and ready to go
camaro1 is offline
post #2 of 27 Old 02-02-2009, 11:01 PM
Moderator
USA1Camaro's Avatar
Looks like you will have a real street terror. What cam specs are you going to run ?
USA1Camaro is offline
post #3 of 27 Old 02-02-2009, 11:11 PM Thread Starter
camaro1's Avatar
im going to start with the Comp Cams XR281HR, intake 228 exhaust 230 (@.050") 0.571" intake .573" exhaust 112 LSA
i had this cam in my L92 head 6.0L s-10 and it ran great, this stroker LS3 having 50ci more than the 6.0L will tame this cam down a bit but it should still make good power
415ci stroker,TVS 2300 Magnacharger, cnc heads, cam, yank ss3200 converter, Kooks long tubes, Bwoody true cold air kit, magnaflow 3" cat-back, lowering springs,BMR control arms and tie rod bars, 3.73 gears, diff mounts,
camaro1 is offline
post #4 of 27 Old 02-03-2009, 06:40 AM
Jonz5GEN's Avatar
Any concerns with too choppy of an idle with the 112 LSA? I suppose a bump in the idle rpm would keep those random misfire codes away.
Jonz5GEN is offline
post #5 of 27 Old 02-03-2009, 06:43 AM Thread Starter
camaro1's Avatar
this cam was actually very smooth at idle in my 6.0 engine, it idled better than the gm hotcam i had in it before
and i have hp tuners, so i will be able to dial in the tune
camaro1 is offline
post #6 of 27 Old 02-03-2009, 06:55 AM
Nice engine Welcome to 5thgen.org
post #7 of 27 Old 02-07-2009, 05:04 PM Thread Starter
camaro1's Avatar
got the correct camaro oil pan installed and the front cover, engine has been pre-lubed/pressurized with oil
camaro1 is offline
post #8 of 27 Old 02-07-2009, 05:27 PM
OctaneZ28's Avatar
Wow, well you're not wasting any time!
Should sound good, strokers always have a unique sound, and that cam will sound nice while being perfectly streetable.
Looking forward to the updates!
OctaneZ28 is offline
post #9 of 27 Old 02-08-2009, 12:00 PM
You planning on putting any miles on the stock motor before you throw this in?
bullydawg is offline
post #10 of 27 Old 02-08-2009, 12:17 PM Thread Starter
camaro1's Avatar
whenever the car comes in ill be swapping engines the next weekend
camaro1 is offline
