Final SAE hp #'s on L99/LS3? - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 8 Old 03-15-2009, 03:37 PM Thread Starter
A New Camaro, Excellent!
Big Phil's Avatar
I thought i read somewhere on here that the L99 is now rated at 410hp & the LS3 is at 426 for the camaro SS.
Just wanted to be sure, b/c everywhere else i read its 400hp for the the L99 & 420 for the LS3.
thanks
1998 White Buick Regal GS
2002 Electron Blue Corvette Coupe
2007 Honda Accord Coupe
2009 Silver Metallic Chevy Tahoe
2011 Convertible Camaro SS comming soon!
Big Phil is offline
post #2 of 8 Old 03-15-2009, 03:58 PM
POWERFREAK's Avatar
is that slight difference in power going to sway your decision on whether you order a A6 or M6?
POWERFREAK is offline
post #3 of 8 Old 03-15-2009, 04:30 PM
The official numbers are still LS3=422HP & L99=400HP, I believe.
Here's a thread that might be illustrative:
http://www.5thgen.org/forum/showthread.php?t=8986
The last post was most curious...
EDIT: As of January 2009, the official 2010 Chevrolet Camaro Specifications guide (v.5) (<http://www.chevrolet.com/camaro/pdf/2010+Camaro+Specifications.pdf> shows the following:
HP
LS3: 426 @ 5900
L99: 400 @ 5900
TQ
LS3: 420 @ 4600
L99: 410 @ 4300
Redline
LS3: 6600
L99: 6000
gto_in_nc is offline
post #4 of 8 Old 03-15-2009, 05:10 PM
If wanna take that one step further and i've pointed it out on here and on tech, is that rating is only at 5,000 rpm..
Got Me SOM is offline
post #5 of 8 Old 03-15-2009, 06:15 PM
54inches's Avatar
I want to take it a step further; please provide the dyno sheets, Mr. Smartelic.
54inches is offline
post #6 of 8 Old 03-16-2009, 10:18 AM Thread Starter
Big Phil's Avatar
Thanks i forgot about that thread.
Well my preference is A6, plus the wife needs to be able to drive it as well. I was just hoping the L99 would be rated higher than the LS2. I know it's a larger block and a little more torque, so that should help.
Big Phil is offline
post #7 of 8 Old 03-16-2009, 02:56 PM
POWERFREAK's Avatar
Originally Posted by Big Phil View Post
Well my preference is A6, plus the wife needs to be able to drive it as well. I was just hoping the L99 would be rated higher than the LS3. I know it's a larger block and a little more torque, so that should help.
Than I would definitely get the manual...so you wont have to let the wifey drive it.
Honestly, don't let the power #'s sway you if you want an A6. The engines are almost exactly the same (both are the same CI). The difference wont be noticeable. The A6 also has a lower 1st gear.
As of now, I'm getting an M6, but I'm friends with a guy who dyno-tunes 'vette's and he's trying really hard to talk me into going with an A6 because of how he's able to tune them (based on his experiences with 'vettes and G8's). If I was buying a car to drive daily or drag-race, I'd would change to an A6.
post #8 of 8 Old 03-16-2009, 03:30 PM
Check out my thread on comparing these two combos -- http://www.5thgen.org/forum/showthre...487#post118487
It isn't perfect but it reveals quite a bit about the effects of the different approaches to gearing and the effect the two power curves have...
