AFM L99 - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 22 Old 03-23-2009, 11:53 AM Thread Starter
hddan's Avatar
AFM L99
Will the L99 have the ability to switch it to a constant 8 cylinder mode? If not, what happens when you do a hole shot? Is there any hessitation when going from 4 to 8 cylinder mode?
hddan is offline
post #2 of 22 Old 03-23-2009, 12:08 PM
Just ask anyone who has an LS4 Monte, Impala, GCP of Lacross Super. There is no hesitation. I've had a LS4 Monte Carlo for almost 3 years, and I don't feel a hesitation under most circumstatnces. The only time I do is if I'm messing with the throttle on/off.
Current Rides
2010 Camaro 2SS/RS
2004 GMC Sierra Z71 regular cab short bed. 5.3 V8
Past Rides
1991 Lumina Euro Coupe, 1994 Lumina Z34, 1997 Buick LeSabre, 2001 Camaro SS, 2006 Monte Carlo SS
04Z7106MCSS10CSS is offline
post #3 of 22 Old 03-23-2009, 01:20 PM
I have often wondered the same thing dan
Jekyll-N-Hyde is offline
post #4 of 22 Old 03-23-2009, 02:38 PM
Yes. Through tuning the AFM can be deleted.
Howard
Redline Motorsports is offline
post #5 of 22 Old 03-23-2009, 03:23 PM
OctaneZ28's Avatar
Howard, it is possible to turn it all the way off? Wow, I was not aware of that. That's cool.
Personally I would like to turn it UP a bit.
Supposedly you can turn it up from 5% to 11% (meaning % of engine load needed for AFM to disengage) and gain 2-3MPG.
And supposedly this can be done in conjunction with a looking-for-more-horsepower tune.
I don't know these things to be fact, but going off what I've heard......
OctaneZ28 is offline
post #6 of 22 Old 03-23-2009, 03:31 PM
AFM is completely adjustable. It is based upon engine rpm, manifold pressure and gear. We have played it with a bit on the trucks but its kind of querky.
There is a paramater to turn it completely off.
Howard
post #7 of 22 Old 03-23-2009, 03:57 PM
Camaro Focus Group Member
SunsetHawkSelena's Avatar
very interesting!
"All alone in my funeral home, playing in blood, there's just got to be something wrong with me" -Slayer-
SunsetHawkSelena is offline
post #8 of 22 Old 03-23-2009, 05:03 PM
Jonz5GEN's Avatar
For those asking about detecting the switch between 4 cylinders and 8 cylinders, it becomes more apparent with aftermarket exhaust through a noticeable change in tone. When cam/heads are added to the equation, it becomes easier to tell through slight 'surges' when applying more throttle at cruising speed, depending on throttle position and engine load.
AFM will not function (or I should say intervene) when in WOT or when in Manual Tap-Shift mode.
Jonz5GEN is offline
post #9 of 22 Old 03-23-2009, 05:58 PM
54inches's Avatar
Great insight.
Thanks!
5thgen.org; killing the Haters since 2002!
54inches is offline
post #10 of 22 Old 03-23-2009, 09:13 PM
By Turning it off do you still have a L99 or basically a LS3 ?
