Headers - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 11 Old 07-17-2010, 08:21 AM Thread Starter
flame19123's Avatar
Headers
What are some good but cheap longtube headers with cats? Im on a budget and i found pacesetter. Are those any good? What are some other good headers?
flame19123 is offline
post #2 of 11 Old 07-19-2010, 01:10 AM
i just ordered a header to tip set of kooks off ebay for $2000 with free shipping... idk what your price range is, but that was a good deal.
DrDarkKnight is offline
post #3 of 11 Old 07-19-2010, 08:44 AM
RedJewel2SS's Avatar
search will give you lots of options, do you already have a cat-back or axle back exhaust installed? if so which one?
if not:
Texas Speed has the cheapest complete exhaust system i have seen to date; $1650 for headers, cats, and 3" magnaflow exhaust.
LG Motorsports has a full system as well with cats is $1795, one of our site sponsors, Speed Inc. sells this one
ARH, Stainless Works, and Kooks are probably the highest quality and each one will run you between $2000 and $2600 depending on where you find it.
i would stay away from pacesetter's, there is a reason why they are so cheap
Gone but not Forgotten!
RedJewel2SS is offline
post #4 of 11 Old 07-19-2010, 06:09 PM
JBA 1 7/8" Stainless Long tubes and Cats are about $1200.00 and they come with o2 extensions and everything needed for install.
Pacesetter is ok but they are mild steel and I would only run them if they were ceramic coated.
2010 4 DW is offline
post #5 of 11 Old 07-19-2010, 07:19 PM
Speed Kills's Avatar
I did Texas-Speed Long Tubes and Hi-Flow Cats for about $1100 shipped. Do not forget the O2 sensor extensions!
IBM RS/SS: Vortech V3 (7.5lbs/boost) Trinity/Dyno Tune/Texas Speed LT w/Magnaflow Comp MGW Shifter/Tint/Heritage Grill/AVIC Z120 Orion Sub & Amp/Bravado Wheels (20 x9.5/11) Just fast enough ... for now!
Speed Kills is offline
post #6 of 11 Old 07-19-2010, 07:34 PM Thread Starter
flame19123's Avatar
I have a borla cat back already. I was looking at kooks but im just not sure yet..want to explore all of my options
post #7 of 11 Old 07-19-2010, 09:30 PM Thread Starter
flame19123's Avatar
A quick question about headers in general..since i already have a cat back system if i went with longtube headers and cats would they fit in the same place as the stock ones or would i have to cut my exhaust?
post #8 of 11 Old 07-19-2010, 09:57 PM
most quality headers are built to mount up to the stock exhaust with no cutting or welding.... since your cat-back was designed to bolt up to the stock manifolds, the headers and exhaust should line right up... ideally!
post #9 of 11 Old 07-20-2010, 03:50 PM Thread Starter
flame19123's Avatar
Is anybody running catless LT headers?
post #10 of 11 Old 07-20-2010, 04:35 PM
i know of someone on here that is... i'll let them reveal themselves if they see it.
from what i hear, you gain a few hp from having no cats... only downside is the exhaust is much louder and of course it is illegal.
if your state doesn't require yearly inspections, then you can get away with it.
if you REALLY wanna run no cats, be sure to buy a catted system, then give the company a call and see if they can send you out off road pipes so you have both options available to you!
