WASHER FLUID BOTTLE REMOVAL ADM AIR SCOOP - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 8 Old 11-06-2010, 11:12 PM Thread Starter
mucker15's Avatar
(WHEN I WENT TO TAKE OUT THE WASHER FLUID BOTTLE I COULDNT FIND ANY PICTURES ON HOW TO DO IT SO I HOPE THIS IS A HELP TO SOME PEOPLE. ) FROM NY5THGEN.COM
SAFELY JACK UP CAR SET IT ON A JACK STAND THEN TAKE OF THE TIRE
TO BE CONTINUED ...........
TOOK ABOUT 45 MINUTES VERY SIMPLE
TOOK HER OUT ON THE ROAD DEFINTLEY NOTICED SOME MORE THROTTLE RESPONSE, ONCE THE AIR SCOOP COMES I WILL POST MORE INFO. IT WOULD MAKE SENSE THAT MORE AIR COMING IN WOULD HELP OUT SO I WASNT SURPRISED AT THE DIFFERENCE. WHAT THE AIR SCOOP WILL DO IS DIRECT THE AIR IN TO THE INTAKE AND SEAL UP THE AREA. WELL SEE. AIR SCOOP SHIPPED ALREADY SO BY NEXT WEEK ILL HAVE THE REST OF THE PROJECT DONE. SO FAR EASY CHEAP MOD. IN THE FUTURE ILL BE ADDING A SMALLER WASHER BOTTLE BEHIND THE COLD AIR INTAKE.
http://s6.zetaboards.com/ny5thgen/topic/8690169/1/?x=0
mucker15 is offline
post #2 of 8 Old 11-07-2010, 09:11 AM
RedJewel2SS's Avatar
ADM has a few videos on how the scoop is installed
http://s281.photobucket.com/albums/k...maro%20Intake/
http://www.camaro5.com/forums/showth...+scoop+install
Gone but not Forgotten!
RedJewel2SS is offline
post #3 of 8 Old 11-07-2010, 07:08 PM Thread Starter
mucker15's Avatar
thanks so much. I am going to post step by step pics when done
mucker15 is offline
post #4 of 8 Old 11-10-2010, 08:51 AM Thread Starter
mucker15's Avatar
recieved the washer bottle today it will require some cutting of the orignal intake mount. Looks like it will be a snug fit. It comes with the wiring needed. Should look nice and clean as soon as I do the work it will be posted up
mucker15 is offline
post #5 of 8 Old 11-10-2010, 09:23 AM
like i've said before, replace the washer bag pump with your stock one! no wiring required.
i didn't do this initially, and the pump went out a couple months later and i had used the fluid maybe twice in between installing it and it failing!
post #6 of 8 Old 11-10-2010, 09:35 AM Thread Starter
mucker15's Avatar
didnt go with the bag though it doesnt look Like I can re use the pump although maybe if i mount it else where scoop should be here friday so ill get into the car saturday hopefully
there is alot more air coming in now
mucker15 is offline
post #7 of 8 Old 11-10-2010, 10:13 AM
cool, post some pics
post #8 of 8 Old 11-13-2010, 05:44 PM Thread Starter
mucker15's Avatar
mucker15 is offline
