Indexing plugs. - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 5 Old 12-05-2010, 10:27 AM Thread Starter
Rodimus Prime's Avatar
Indexing plugs.
Just wondering if anyone here has bothered to index their plugs when installing them, or if anyone has tried to verify an actual power increase from it. For the extra 10 minutes of your time do you think its worth it if you gain any power?
No reason was specified.
Rodimus Prime is offline
post #2 of 5 Old 12-05-2010, 11:02 AM
I indexed plugs back when things were carbureted and lower power ignition systems and overall tech was lower. Made quite the difference then....
But these days it doesn't make much difference. I did it for the hell of it on my 97 Silverado when I bought it as it had a weird miss at idle and it had new plugs in it already. Made no difference. Turned out it was the new plugs! Changed them to NGK double platinum's and have never had a prob since...
Fine wire (Iridium and some platinum) plugs will make a difference as they drastically open up the "kernel" area and give great tip-in and response feel as well... Don't use em tho if you are on forced induction, they can't shed enough heat fast enough....
post #3 of 5 Old 12-05-2010, 03:49 PM
el ess X's Avatar
Indexing for the street is futile and a waste of time. It worked when combustion chambers and fuel/ignitions systems were fairly inefficient. That problem has seemed to correct itself via better engineering.
el ess X is offline
post #4 of 5 Old 12-05-2010, 04:05 PM
dconradt's Avatar
What he said.
dconradt is offline
post #5 of 5 Old 12-05-2010, 07:45 PM
I've done it on one of my carbureted bikes, it's got 2 cylinders and 4 plugs;
can't say that I noticed much of a difference.
I don't think I'm energetic or bored enough to try it on a V8 Camaro.
rmnc3r is offline
