Fitted a Whipple Supercharger to my 2SS over the weekend - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 19 Old 03-30-2011, 12:23 PM Thread Starter
Simon.w's Avatar
Hey everyone,
well I had a busy weekend ... I fitted a Whipple SC kit along with BBK Headers to my 2011 2SS Manual. I was already running Cold Air Inductions CAI, ADM Race Scoop, GM Performance Exhaust, Hurst Billet Comp Plus Shifter.
I can not recommend the Whipple Kit highly enough ... it is AWESOME! So well put together, excellent detailed instructions, labeled bags with individual hoses, wiring etc ... and the hand-held tuner with the custom Whipple tune set up for my configuration.
I started Friday night and had the car running Sunday night ... so a big job, but very satisfying knowing I did it all myself.
And how does it go? WOOOOOOOOOOOW!
782.5rwhp 680 rwtq 2011 Inferno Orange 2SS, STRUT 22" Icon5 Rims & Grille Kit, Mahle Pistons, Manley Rods, Custom Comp Cam, ARP Bolts, Melling HV Oil Pump, Whipple SC, 3.5" Pulley, 8 Rib Pulley Kit, Innovators West 10% Overdrive Balancer, LT Headers, Borla 3" Exhaust, ADM Fuel Pump, 80lb/hr FIC Billet Tip Injectors, RX Monster Catch Can, CAI Intake, ADM Race Scoop, Mantic 9000 Series Clutch, Hurst Shifter, Eibach Springs. Motor built by PFAFF Engines. Fitted & tuned by Cunningham Motorsports.
Simon.w is offline
post #2 of 19 Old 03-30-2011, 12:26 PM
LuckyMe's Avatar
looks good .
2011 2SS/RS , summit white with IOM stripes .Flowmaster American Thunder catback exhaust.
LuckyMe is offline
post #3 of 19 Old 03-30-2011, 04:05 PM
Very Nice, Looks Great and I'm sure it Runs even Better!!!!!
post #4 of 19 Old 03-30-2011, 04:07 PM
odoylerulez55's Avatar
man that looks sweet!
94' Z28 sold 12/14/09
odoylerulez55 is offline
post #5 of 19 Old 03-30-2011, 09:35 PM Thread Starter
Simon.w's Avatar
Thanks guys!
Simon.w is offline
post #6 of 19 Old 03-30-2011, 09:36 PM
spckatnip's Avatar
Looks great. If you do not mind me asking how much did this setup run?
2011 2SS CGM/IO Convertible - MySSt
spckatnip is offline
post #7 of 19 Old 03-30-2011, 09:59 PM Thread Starter
Simon.w's Avatar
Polished Whipple kit with hand held tuner $7800 (that's not fitted ... I did it myself)
Headers, CAI, ADM Scoop, Hurst Shifter, Eichbach, Exhaust .... add around another $3k.
Simon.w is offline
post #8 of 19 Old 03-31-2011, 02:34 AM
Jason's Avatar
May be a stupid question but did u pull the motor to install the kit.?
Jason is offline
post #9 of 19 Old 03-31-2011, 09:03 AM
Sarge12R's Avatar
Nice job! Looks great!
Sarge12R is offline
post #10 of 19 Old 03-31-2011, 09:15 AM Thread Starter
Simon.w's Avatar
No ... pulled the front clip off to fit heat exhange and electric water pump for intercooler ... but that is half an hour job.
You just have to remove fuel lines, air box (or CAI in my case), coil packs, unplug and pull back looms, run new hoses to back of the SC for the intercooler, replace the heater hoses with more direct ones that dont run over the engine, remove the intake manifold, then bolt on the supercharger (after you've filled it with oil and coolant mix) in sections, then bolt on the throttle body.
You also have to remove electric fan assembly to give you better access to harmonic balancer bolt ... which you replace and pin.
And then there's the MSD fuel booster that is mounted into the trunk and the loom that runs underneath the car up to the engine.
Replace fan assembly, front end, radiator hose, spark plugs, coils, plug leads, looms, fuel lines, vacuum lines, throttle body, fit new pulley assembly, fit new serpentine belt, CAI.
Top up coolant levels
Then plug the tuner in, save stock tune, upload new tune.
That's VERY condensed ... but pretty much the way it rolls. I did the headers at the same time which added about 4-5hrs to the job.
Simon.w is offline
