Seaping oil - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 13 Old 10-12-2011, 06:18 PM Thread Starter
ffej0127's Avatar
Seaping oil
Ok guy's, put your thinking caps on. I have been using Amsoil synthetic for almost 2 years now. but when i use the high mileage filter from amsoil i seem to have an oil seaping problem through the very bottom of the oil pan and a little on the lower end of the oil cooler. i have the 6.2
It has been at the dealer and had dye in the oil to try to locate a leak, but none found. If i swap out the filter and go with a standard ac delco filter and clean the oil that has appeared, it stays bone dry and do not get one ounce of seaping anywhere!
I am very confused, so i have a bunch of people trying to figure it out including amsoil. someone has mentioned that maybe the filter causes excessive crankcase pressure and therefore it seaps. just a theory.
Any ideas or has anyone else run across any simaliar problem?
2SS..IO Interior M6 Black Rally Stripes Borla Mufflers Diablo Tuned 20% Tints Vararam ram air, Eibach front and rear sway bars, BMR trailing arms, BMR toe rods, BMR lower control arms, BMR strut tower brace, SLP Long tubes with high flow cats Granetelli cross drilled and slotted rotors BBK 95mm Throttle body Eibach coil overs, BMR Adjustable Front and Rear Sway Bar End Links Bravado 20" Rims with Eagle F1 305/35/20 in the Rear and 275/35/20 front
ffej0127 is offline
post #2 of 13 Old 10-12-2011, 06:44 PM
Sorry to hear that... I'm getting ready to make the Switch to Amsoil so I will keep a watch out for what U find out...
post #3 of 13 Old 10-12-2011, 07:15 PM
I would just keep the amsoil and keep the gm filter.Unless there is a reason not too.
post #4 of 13 Old 10-12-2011, 08:00 PM Thread Starter
ffej0127's Avatar
Thats what im going to end up doing, but it just rattles my brain and i would like to know why this is happening. there is no logic to this problem.
ffej0127 is offline
post #5 of 13 Old 10-13-2011, 06:08 AM
Dose it leak with more than one filter, ie have you tried it with a couple of amsoil filters.
post #6 of 13 Old 10-13-2011, 05:38 PM Thread Starter
ffej0127's Avatar
no. just the high mileage one. i gonna try a different one this weekend. like a mobil one high mileage or some other brand besides ac delco or amsoil and see what that does.
ffej0127 is offline
post #7 of 13 Old 10-13-2011, 05:45 PM
Artful Dodger's Avatar
I use the K&N oil filter with the nut on the case. No need for a filter wrench.
Dodger
http://www.southjerseycamaro.com
ModernCamaro Member/Car of the Month: May 2012
Artful Dodger is offline
post #8 of 13 Old 10-13-2011, 08:49 PM
Alfieboy's Avatar
why even use a hm filter..your mileage that high?
Alfieboy is offline
post #9 of 13 Old 10-13-2011, 09:20 PM
745RWHP, 660RWTQ
BLACK10's Avatar
I agree, the regular filter or a K&N filter would work. Also, maybe contact SC2150 and get the oil cap with the breather on it. That will help relieve pressure
BOURQUE'S HOT RODS
[email protected], 1.455 60'
Built 376ci, TH400 Trans
BLACK10 is offline
post #10 of 13 Old 10-13-2011, 09:54 PM Thread Starter
ffej0127's Avatar
Good idea, ill look into the breather cap. Thanks for the help everyone.
ffej0127 is offline
