Cam question?? - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 5 Old 10-27-2011, 12:21 AM Thread Starter
1Nastymaro's Avatar
Cam question??
Has anyone put in a LS9 cam in there l99 if so what HP did it make i can get a brandnew one for cheap?
1Nastymaro is offline
post #2 of 5 Old 10-27-2011, 03:15 PM
Not sure of anybody who has put that cam in a Camaro. Looks like you have long tubes, exhaust and a tune? This cam would give you a little more power (maybe 30hp), but you may actually lose a bit of torque as well. The LS9 cam is focused on use for a supercharger, and towards pleasing the average customer who is not power hungry. It wouldn't make a great naturally aspirated cam, unless you are definitely going to go forced induction down the line, and even then, its a very mild cam. Either way it probably wouldn't be worth the cost/time of installation.
As you probably know, our L99's are equipped with Variable Valve Timing, and Active Fuel Management. When swapping cams, these things must be removed, which means pulling the heads, replacing the lifters, the engine valley cover, the front cover, and the cam sprocket. It's quite a job on an L99 engine, and therefore would probably not be worth it to put a little cam in. The good thing about it though, once you have done these things, they are good for any other cam you choose to install, and takes a lot less effort/money to replace it again down the line if you want to upgrade further.
It is possible to change the cam without removing these things, using a VVT cam, but cam choices are very limited, especially if you retain the stock lifters. The AFM lifters are very weak when other valvetrain components are replaced with stronger parts. Even in stock situations, they can and do fail.
Don't let me discourage you, replacing the cam and getting rid of these things is a spectacular mod, my favorite to my car for sure: the power, the sound, the rock and roll, and the freedom from the AFM lifters is awesome! But unless you plan on doing the work yourself, and want to do a lot of work, I'd spend an extra couple hundred and get a good cam, you will be much happier.
- Jeremy
post #3 of 5 Old 10-27-2011, 08:11 PM Thread Starter
1Nastymaro's Avatar
Thanks for the great info do u have a cam in your is so what one?
post #4 of 5 Old 10-28-2011, 09:20 AM
2010_5thgen's Avatar
jasond from camaroz28.com has done that. maybe head over there and ask him some questions.
Brixton Forged
2010_5thgen is offline
post #5 of 5 Old 10-28-2011, 10:59 AM
I do have a cam in my LS3 style L99, I actually put in a mild blower cam to experiment with in a naturally aspirated car. I say mild, but it is actually a decent amount bigger than the LS9 cam. It does OK, gained about 40rwhp and 3rwtq from the stock VVT cam, but I'm not really pleased with it in my car; if I had to pay the ~$1700 in labor, I really wouldn't be pleased. As soon as I get some time, I'm swapping in an aggressive naturally aspirated cam.
- Jeremy
