Dyno Issues - Stabilitrak - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 12 Old 12-11-2011, 10:37 PM Thread Starter
lonestar.camaro's Avatar
Exclamation Dyno Issues - Stabilitrak
I tried to dyno my 2010 SS this weekend with no luck. Stabilitrak kept stopping us from continuing with error codes, etc. Did the "7 second" hold to "disable" the system with no luck. Also tried abs turned off. Also tried competitive mode. Anyone else come across this issue? Is there a fuse that needs to be pulled?! Thanks-
lonestar.camaro is offline
post #2 of 12 Old 12-12-2011, 01:31 AM
When I dyno'd mine the instrument panel lite up like a Christmas tree. Thats normal. Just your cars computer thinking that something is wrong because your car is hauling a$$ and the front tires are setting still. Once the ECM gets back on the road it will re-read it and everything will go back off. hope this helps.
post #3 of 12 Old 12-12-2011, 02:25 AM
Mine did also then went off after awhile
post #4 of 12 Old 12-12-2011, 11:24 AM Thread Starter
Right - I'm used to the lights coming on, and they did clear once I drove it down the block. The issue is that it is physically limiting power and speed to about 40mph, I believe. It's going into a safety mode.
post #5 of 12 Old 12-12-2011, 11:33 AM
Just curious...since I'm local...where did you go for the dyno?
post #6 of 12 Old 12-12-2011, 02:47 PM Thread Starter
Redline Performance, LLC in Arlington. Nice guys, and they did try their best to reconcile the issue. I'll be going to 21st century in Addison from now on though.
post #7 of 12 Old 12-14-2011, 03:10 PM Thread Starter
Thumbs up
Issue resolved - idk what the Arlington shop was doing wrong but the guys at 21st Century Muscle Cars in Addison did it right! I'll post the official numbers in the appropriate thread.
post #8 of 12 Old 12-15-2011, 06:10 AM
ModernCamaro.com Sponsor
Tampa Tuning's Avatar
Did you turn off the traction control on the dyno?
You may be throwing the codes for your front wheels. The vehicle doesnt understand why your rear wheels are spinning and your fronts are not.
If you clear the codes and its still on, Disconnect the postitive terminal from the battery for about 15-30 mintues to force everything to reset. Before you start the car after the reset, make sure all the codes are clear, and you should be good to go.
Tampa Tuning is offline
post #9 of 12 Old 01-06-2012, 08:48 PM
BubbaHD's Avatar
Sounds like they were using a pirated program or didn't keep up with their licence. If they don't pay HP for updates, they can't play.
No Hope
Ratt
BubbaHD is offline
post #10 of 12 Old 01-06-2012, 09:22 PM
shawn29's Avatar
^^Had the exact same thing happen to mine on the exact same day , on the exact same dyno
shawn29 is offline
