Heads and Cam running 10's - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 31 Old 03-28-2012, 09:30 AM Thread Starter
Here is a link to our 5th Gen M6 running 10's with just heads and cam.. check out the video it gives all the rwhp/rwt and shows the car shifting all the way down the track, it also gives an idea on the idle and how GREAT it sounds!!
Cartek Heads and Cam Dragan-XR package - YouTube
post #2 of 31 Old 03-28-2012, 10:17 AM
Darkrider's Avatar
modifications:
Kooks 2" long tube headers
Kooks off-road x-pipe
Cartek ported and machined (in house) 4X LS3 heads
Cartek custom grind camshaft
Cartek ported 90MM throttle body
Cartek ported 102MM FAST intake
Cartek custom tuning
Vararam CAI
Under-drive pulley
Monster clutch
Cartek 4.10
How exactly does that equal "just heads and cam"?
That's more than "just heads and cam", but I digress. Nice car and a monster at 515whp/471wtq all motor. My plan is to go all motor as well, but I'm hoping for over 500wtq with 500+whp.
Darkrider is offline
post #3 of 31 Old 03-28-2012, 10:20 AM Thread Starter
true.. its a bit more then heads and cam... i should have said heads and cam with bolt ons... i didnt really have my coffee yet but thanks for the props!!!
Good luck on your build.. let us know if you would like a package from us.
post #4 of 31 Old 03-28-2012, 04:26 PM
Nice! There sure is a lot of room in these engines!
post #5 of 31 Old 03-28-2012, 06:03 PM Thread Starter
You bet their is... and a lot of power we can get out of them!!
post #6 of 31 Old 03-29-2012, 07:01 AM
CC Performance Parts's Avatar
Most people do bolt ons before doing heads and cam so when you say heads and cam then it is automaitically assumed the bolt ons are in place as well
Fixing the LSx world one misconception at a time
CC Performance Parts is offline
post #7 of 31 Old 03-29-2012, 07:35 AM
fhpe77's Avatar
Just d***! Amazing potential for these cars. I'm not prepared to terminate the power train warranty on my daily driven SS, but now I'm thinkin' five years can't come soon enough.
fhpe77 is offline
post #8 of 31 Old 03-29-2012, 12:02 PM
Wraith's Avatar
Mind if I ask what you did to the drivetrain? I'm guessing its not stock
Wraith is offline
post #9 of 31 Old 03-29-2012, 12:11 PM Thread Starter
Other then a clutch and gears and a aluminum drive shaft? The trans is stock, the rear housing is stock and it is a stock bottom end.
post #10 of 31 Old 03-29-2012, 01:14 PM
Wraith's Avatar
That's good to know. I like to see how the stock equipment holds up. My '78 has a stock T-10 and 10-bolt, with an aftermarket clutch and driveshaft behind a 468BB. Never had an issue with the 10-bolt, but the rear in my '99 TA was a piece of junk.
Thanks for the response
Wraith is offline
