getting CAI cold air induction but do i need the scoop? - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 11 Old 03-30-2012, 07:51 AM Thread Starter
I was talking about this over at Camaro5 forum but wanted to get more opinions!
thinking about doing the CAI Inc cold air induction on my 2011 2SS.
Can anyone who has done and also installed the Apex Motorsports Cold Air Intake Scoop and the Apex Motorsports Washer Fluid Tank Replacement Kit tell me if its worth adding those two options? Is the cold air induction enough?
The price for the scoop is fine - but if its only a minimal improvement, I'll stick with just the induction - but if the scoop is awesome in terms of more power/better mpg (oxymoron i know) then i'll go for it.
thanks!
Jasonw86 is offline
post #2 of 11 Old 03-30-2012, 08:29 AM
I helped install it in a friends car last month. The hardest part is using the dremmel to cut some plastic out of the way. Best answer is you don't need it if you get rid of the washer fluid bottle. If you want to keep it then you need the scoop and relocation bottle. It took us a few hours to do it.
JULY 2013 M.O.M winner!
Strick is offline
post #3 of 11 Old 03-30-2012, 08:32 AM
Here's the after pic when I removed my water bottle bs the before
Before
This was on my car.
Strick is offline
post #4 of 11 Old 03-30-2012, 01:46 PM Thread Starter
so is adding the scoop and relocating the washer res going to give me a noticeable change in power/better gas mileage vs just doing the cai?
2011 2SS/RS White Camaro Convertible
Jasonw86 is offline
post #5 of 11 Old 03-30-2012, 09:33 PM
I really don't think you will feel anything. Maybe pick up 1 or 2 hp from the scoop if you're lucky.
Strick is offline
post #6 of 11 Old 04-01-2012, 02:56 PM
Can you post a Dyno showing 3-4 hp gain using the scoop with the CAI and then a Dyno with the CAI and no scoop???
Strick is offline
post #7 of 11 Old 04-01-2012, 04:25 PM
wrbear's Avatar
I installed the CAI Inc. setup myself. I did not add the scoop though. I've had it on the car going on 2 years. No impact without the scoop for me.
WRS
“Knowledge is knowing a tomato is a fruit; Wisdom is not putting it in a fruit salad.”
wrbear is offline
post #8 of 11 Old 06-08-2012, 09:09 AM
Rednblak's Avatar
I would think the scoop would only show its true benefit at speed, when air is being forced in from the front of the car, whereas on the dyno it will only show what benefit it gets from providing more open space for airflow below the CAI.
I installed both myself though and felt it was a good addition. If you're just worried about performance install the scoop and leave off the washer bottle to save weight in my opinion.
Rednblak is offline
