Pulley Install!! - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 7 Old 08-07-2012, 02:58 PM Thread Starter
Pulley Install!!
I just had an SLP under drive pulley installed. I had a local shop I'm familiar with do the work. It came out pretty good. And the car moves out a bit better than before. Overall impression...I'm pretty happy with it!!
post #2 of 7 Old 08-07-2012, 04:07 PM
See You On Course
CUONCRS's Avatar
So, I've heard of this, but not sure what it does. Can you enlighten me on what it is and what it does?
2010 Stock IBM 2SS/RS
CUONCRS is offline
post #3 of 7 Old 08-08-2012, 01:21 AM Thread Starter
It is simply a crankshaft pulley like the stock one on your engine. The difference is that this one is smaller in diameter than the stock pulley and so it spins the accessory pulleys (mainly the water pump and alternator) slower. This frees some of the hp/tq that the accessory pulleys use up. It's supposed to be approximately a 6 RWHP gain seen at all RPMs. And it causes no issues with the cooling or charging systems. It also improves gas mileage. I got it used from a member on here.
post #4 of 7 Old 08-08-2012, 08:54 AM
See You On Course
CUONCRS's Avatar
Oh, cool. Thanks! So does the tensioner take up the slack and you use the same belt, or does it need a new size after the change?
CUONCRS is offline
post #5 of 7 Old 08-08-2012, 01:26 PM
BBQdDude's Avatar
NORMALLY the same belt is used. Not sure on the Camaro though as I haven't done this one....yet.
BBQdDude is offline
post #6 of 7 Old 08-08-2012, 01:49 PM Thread Starter
The difference in diameter is too great to retain the stock belts. SLP sells 2 new belts with the pulley and a new crank bolt. Because you can't re-use the bolt either. The guy who sold me the pulley also gave me the 2 belts for it. I had to go to a dealer to get the bolt...it was only $10.22.
post #7 of 7 Old 08-08-2012, 02:06 PM
BBQdDude's Avatar
I sit corrected .
BBQdDude is offline
