VMAX throttle body install, what size? - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 8 Old 09-06-2012, 07:48 PM Thread Starter
I did a search but couldn't find any discussion on throttle body install.
I'm in a process of buying a VMAX throttle body but am concerned if I will be able to install it. From what I've been able to find it sounds like a pretty easy job.
How hard is the throttle body to install? On a scale of 1-10 I'm about a 4 on the mechanic scale, I'm comfortable doing minor repairs and installs.
Has any one had a problem with their CAI when installing the throttle body? I have a G5CR CAI, I want to make sure the CAI and the throttle body are compatible together before I start the work.
It looks like there are several different sizes of throttle bodies. What size did you guys go with? I have a LS3 engine and I don't want to have to modify or change anything else to accomodate the VMAX throttle body.
Thanks in advance for your help!
Russ
ohioss is offline
post #2 of 8 Old 09-07-2012, 12:50 AM
Russ
There is only one that will work with your car. Nevermind all the sizes listed. You will inform them what car you have and they'll get a ported and polished TB for your car. The install is probably easier than doing a CAI. You disconnect the intake tube, unplug the TB, loosen and remove the bolts, and reverse the process for the V-Max TB. It'll take you 10 minutes. You won't need to modify or alter or change anything. Just make sure everything is plugged back in. And don't go crazy when you tighten the bolts. Make sure you torque them down to spec.
post #3 of 8 Old 09-07-2012, 02:45 AM
I installed the VMax TB in my V6 all by myself in less than 20 minutes...and I'm just a girl with little experience...so I know you can handle the job. And I did take pictures every step of the way so I'd be happy to add some if you want me to?
post #4 of 8 Old 09-07-2012, 10:14 AM
Sickness91Z28's Avatar
yeah, it's super easy. I get mine today
2010 Camaro RS/2SS-BLOWN!!
LS3, SLP TVS2300 Supercharged, M6, Hurst Short Throw Shifter
Kooks LT Headers, Kooks High Flo Cats, QTP Cutouts, ADM Race CIA,
ZL1 Wheels, Eibach Springs
Sickness91Z28 is offline
post #5 of 8 Old 09-07-2012, 02:38 PM
javi05's Avatar
might need this then... lol..
2011 camaro 2ss convert..black on black. Slp black wing intake, k&n drop in , muffler delete , 93 octane diablo tune L99/A6. totaled 12-4-13..
2014 camaro 2ss 1LE. best car yet!!!!
javi05 is offline
post #6 of 8 Old 09-07-2012, 05:12 PM Thread Starter
Chapel- thanks again, you have been very helpful.
Envy- thanks for the offer but it sounds like a very easy install so I should be fine.
Russ
ohioss is offline
post #7 of 8 Old 11-22-2013, 02:19 PM
gomezcorp's Avatar
Who knows what the stock throttle body diameter for an LS99 engine on a 2011 camaro SS is
gomezcorp is offline
post #8 of 8 Old 11-22-2013, 02:44 PM
90mm...
