Dyno video - 732rwhp CMS built & tuned, Whippled PFAFF Racing Engine - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 9 Old 04-19-2013, 10:58 AM Thread Starter
Simon.w's Avatar
So it's finally ready ... and well worth the wait!
732rwhp + 644ftlbs ... what a brilliant effort!
A HUGE thank you to Ryne and Mike and CMS and Gordy, Joe and Steve at PFAFF Engines, Chris and Tim (TA Performance) from Mantic.
I am absolutely confident that I had the very best people in my corner on this project ... and the results speak for themselves!
Cms built whippled 2011 Camaro 732rwhp 644 rwtq - YouTube
782.5rwhp 680 rwtq 2011 Inferno Orange 2SS, STRUT 22" Icon5 Rims & Grille Kit, Mahle Pistons, Manley Rods, Custom Comp Cam, ARP Bolts, Melling HV Oil Pump, Whipple SC, 3.5" Pulley, 8 Rib Pulley Kit, Innovators West 10% Overdrive Balancer, LT Headers, Borla 3" Exhaust, ADM Fuel Pump, 80lb/hr FIC Billet Tip Injectors, RX Monster Catch Can, CAI Intake, ADM Race Scoop, Mantic 9000 Series Clutch, Hurst Shifter, Eibach Springs. Motor built by PFAFF Engines. Fitted & tuned by Cunningham Motorsports.
Simon.w is offline
post #2 of 9 Old 04-19-2013, 01:03 PM
Very impressive!!
post #3 of 9 Old 04-19-2013, 02:37 PM
javi05's Avatar
wowzers!!!! good job!
2011 camaro 2ss convert..black on black. Slp black wing intake, k&n drop in , muffler delete , 93 octane diablo tune L99/A6. totaled 12-4-13..
2014 camaro 2ss 1LE. best car yet!!!!
javi05 is offline
post #4 of 9 Old 04-19-2013, 02:43 PM
monzaruba's Avatar
wowww...
http://i261.photobucket.com/albums/ii75/monzaruba/foto3_zps6fbde664.jpg
A Camaro you steer with the rear wheels...!
monzaruba is offline
post #5 of 9 Old 04-19-2013, 09:22 PM Thread Starter
Simon.w's Avatar
Thanks everyone ... yeah pretty happy with that result! (understatement of the year!)
Simon.w is offline
post #6 of 9 Old 04-21-2013, 08:56 AM Thread Starter
Simon.w's Avatar
Well I brought it home today ... didn't want the 1 & 1/4 hr drive to end! It is totally the best of everything. Sounds unbelievably tough when its sitting there idling, then gets up and pulls incredibly strong all the way through the rev range ... and then becomes very civilized on the highway with no drone or cam surging.
LOVE IT! Thanks Ryne!
Simon.w is offline
post #7 of 9 Old 04-21-2013, 09:29 PM Thread Starter
Simon.w's Avatar
Dyno sheets
Here are the dyno sheets:
Simon.w is offline
post #8 of 9 Old 04-22-2013, 12:41 PM Thread Starter
Simon.w's Avatar
Gotta also say, that Mantic 9000 Series clutch is amazing. Pedal feel is no harder than stock, no shudder or slipping issues .... even with a big cam and over 700rwhp.
This is what I ended up going for: Performance Clutches | Twin Disc
Simon.w is offline
post #9 of 9 Old 04-27-2013, 05:44 PM
S.Bretz's Avatar
Yeah, twin disc units are awesome like that. I a lot of cases you can get away with using stock material on the friction discs to that you still get a long service life out of the unit plus double the torque holding capacity at no extra pedal effort.
Kevlar has an even longer service life yet I don't see it used much. Its either OEM material or ceramic. The ceramics hold a lot better, but I have been threw too many of them..the ceramic eats the **** out of the pressure plate and the flywheel. If you had an aluminum flywheel its not much of an issue since you can get new inserts, but if you have a steel FW, then you have to resurface...and can only take out so much before on some cars before you have adjustment issues or friction disc to spline contact issues on the trans input shaft; if the disc does not slide all the way onto the splines the powertrain will vibrate like crazy because the disc will clamp slightly off center.
S.Bretz is offline
