Elite Catch Can: Having Trouble Aligning 90 deg Hose Barn Fittings In Right Direction - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 6 Old 07-27-2013, 05:15 PM Thread Starter
camarodude's Avatar
Ok, I'm an idiot (today), as I try to install my Elite catch can as I type this.
I can't seem to be able to point the two Hose Barb fittings in the right direction on the catch can. Logically, they should be aimed towards the engine after tightening them. Mine are way off as you can see in the pic. How did you guys align yours? Did you have to use a washer? Im
camarodude is offline
post #2 of 6 Old 07-27-2013, 05:46 PM
83Hokie's Avatar
I just did my RX CC and had the same issue ... called up and they told me to use a screwdriver to turn them ... I put a large Phillips in and a bit of slow pressure and it worked ... was worried about breaking it at first but it went fine .. gentle steady pressure on the RX, I assume the same for Elite
83Hokie is offline
post #3 of 6 Old 07-27-2013, 07:22 PM Thread Starter
camarodude's Avatar
I dunno man...it really doesn't sound like it's the same design here, concerning those 90 degree hose barn fittings, that need to be threaded onto the catch can. You can only twist them so far by hand. Any more and the threads will surely strip.
Wrapping some Teflon Tape over the thread might be the ticket here. Sadly I don't have any. I guess no test drive tonight
post #4 of 6 Old 07-27-2013, 07:25 PM
Play it safe, "when in doubt...don't", that motto has saved my A$$ many times.
post #5 of 6 Old 07-28-2013, 05:31 AM
83Hokie's Avatar
Agree, I had called them and they told me to do it (and said they would replace it, if it broke) ... probably need the same guidance from Elite before doing it.
83Hokie is offline
post #6 of 6 Old 07-28-2013, 03:19 PM Thread Starter
camarodude's Avatar
Ended up adding some plumbers Teflon tape on the threaded end of the fitting. I hand tightened to start until I couldn't tighten it anymore. Then I wrapped a towel on it, took out a long tool to add leverage, and it spun around nice and smoothly. All is well now. Just to reiterate, hand tightening alone doesn't seem to be enough.
Took Sledge out for a good hard run (no rev limiter hitting mind you), with 600 miles(1000km) on the clock, boy do I feel good having installed both the Elite can and the Chevrolet Performance supplied Oil Separator kit
Just wanted to note, upon sticking a Q-tip inside the original hose to install the oil separator kit("clean side") I observed one to two at most, clean looking drops of oil in there. Nothing significant at all, but considering that I haven't even hit the track yet, something worth considering.
As for the "dirty side" where the catch can goes, although the oil looked clean inside the nipple leading to the engine, and the hose itself that needed to be removed, there was a significant amount of oil in there. By that I mean, estimate perhaps 10-20 drops of clear looking oil.
Highly recommended mods no doubt about it!
