Just emtied my catch can - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 28 Old 07-29-2013, 06:22 PM Thread Starter
Rock on's Avatar
the thought I would share what I got after 880 miles this is an Elite and I have had 2 fresh oil changes because I just had my cam installed
ID:	24818   Click image for larger version
Faster than a speeding ticket, Comp.621/.624 235/251 113, ls3 conversion, 660 platinum spring, Comp trunion rocker upgrade, Katech C5R timing chain, Kooks 1 7/8 long tubes with cats, Yank 3600 stall, Elite catch can, K&N 63 series cai, 160* thermostat, window tint, Rockford Fosgate sub. Magniflow resonated X, muffler delete.
Rock on is offline
post #2 of 28 Old 07-30-2013, 07:40 AM
PNYSLAR's Avatar
wow
2010 Camaro's are GM's best idea yet!!!!
2SS/RS Black on Black, M6 Sunroof
2012 Summit White ZL1, M6, Sunroof
"Thank you Champion Chevrolet!!!!" #1588[
PNYSLAR is offline
post #3 of 28 Old 07-30-2013, 07:41 AM
SC2150's Avatar
The better your rings are seated/sealed the less you should catch.
SC2150 is offline
post #4 of 28 Old 07-30-2013, 08:57 AM
Towlie's Avatar
I agree with this statement. But that doesn't seem like a lot for 1000 miles on a 6.2L engine. Pulling the crank case pressure brings all that oil vapor from the block, as well as blow by. As I'm new to Ls motors, some one please clarify if I am mistaken. Thanks. :-)
2013 2SS/RS with the flappy paddle crap
Towlie is offline
post #5 of 28 Old 07-30-2013, 04:40 PM
CyCam1's Avatar
You really don't need a Catch Can on a V8. Waste of money. The real issue is on DI V6 engines. The jury is out.
CyCam1
CyCam1 is offline
post #6 of 28 Old 07-30-2013, 05:05 PM
MidnightSSS's Avatar
absoutley correct x2
April 2013 COTM Winner
MidnightSSS is offline
post #7 of 28 Old 07-30-2013, 08:42 PM
Towlie's Avatar
Good to know about the v6 and I kind of figured as much about the catch can. It's when you do forced induction or crazy high compression builds, that crank case ventilation becomes an issue.
Towlie is offline
post #8 of 28 Old 07-30-2013, 10:37 PM
J-ROD-210's Avatar
I'll try to posts pics when I empty mine. I usually get plenty of oil. Yup on a. V-8, but I'm sure the anti- catch can brigade we have here will probably say I bought a catch can that was pre-filled with oil so I could believe that it works.
J-ROD-210 is offline
post #9 of 28 Old 07-31-2013, 06:21 PM
SS Talia's Avatar
I was on the fence before I went and pulled the trigger. I did some searching and found some who swore by it and others claiming poppycock. I like having piece of mind and since I plan on keeping this baby forever and ever and ever and ever and ever, I picked one up. If it didn't do anything, i'd resell it.
I've had it on for about 3000 miles and there's oil in there.. so now i'm one of the believers
SS Talia is offline
post #10 of 28 Old 07-31-2013, 11:09 PM
CyCam1's Avatar
You have a V8... no issue at all. V8s have port fuel injection that cleans the pistons. What are you saving the oil for...to dump back in??? It won't hurt anything on a V8. No sense in wasting your money so you can say you had to empty an unnecessary can. ???????? WTF
CyCam1
CyCam1 is offline
