Cam Options - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 38 Old 10-29-2013, 03:39 PM Thread Starter
MidnightSSS's Avatar
Cam Options
Whats a great street/track cam for a M6 LS3?? that would make great power but still keep driveablity? also would would i need to upgrade as well?? thanks for any help
April 2013 COTM Winner
MidnightSSS is offline
post #2 of 38 Old 10-29-2013, 04:51 PM
Your best bet for a good cam is to find a company or Vendor you would purchase it from and contact them. More and more cams are custom grinds. And most companies have expertise advice on what kind of grind would best suit you. If you tell them what you're looking for out of it and even what other future mods (heads, stroker, supercharger, nitrous, etc) then they will be able to make you a custom cam that will not only give you a good boost now but it will also work optimally for your future set-up. TSP is a good place to contact. And there are several other good names. But I would probably go with TSP when I get mine. They'll also tell you what you need to upgrade and what can be re-used.
post #3 of 38 Old 10-29-2013, 10:19 PM Thread Starter
Thanks Chapel, yea ive heard good things about TSP, just wanted to know if the springs or rockers lifters needed to be replaced?? I guess I will give them a call when im ready
post #4 of 38 Old 11-01-2013, 10:19 AM Thread Starter
been hearing a lot about the nighfury cam
post #5 of 38 Old 11-02-2013, 09:27 PM
I have the Livernois Maxx R cam and it does not like to be driven under 1800 rpms. Makes great top end power. Livernois replaced valve springs to a dual setup as well as retainers and pushrods. They have a 2C cam that has better drivability. Car wants to buck when driven at lower rpms.
Fifthgenfire is offline
post #6 of 38 Old 11-03-2013, 06:09 PM Thread Starter
yea I want something with better driveability, what are the specs?
post #7 of 38 Old 11-08-2013, 11:18 AM Thread Starter
what numbers did u put down?
post #8 of 38 Old 11-09-2013, 05:34 PM
Midnight, what are you looking for in a cam?
post #9 of 38 Old 11-11-2013, 01:03 PM Thread Starter
a nice lope, decent driveability and good power without having to spend a ton, etc changing fuel upgrades
post #10 of 38 Old 11-19-2013, 03:49 AM
JCunningham's Avatar
any cam will require new springs.
JCunningham is offline
