Duel Mode Exhaust - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 10 Old 03-16-2014, 05:29 PM Thread Starter
Duel Mode Exhaust
Hi all,
I hear all the time about removing the fuse for Duel mode exhaust.
What about just taking off and plugging the vacuum hoses to each side?
What would be the downfall in doing this?
Swanys 2SS is offline
post #2 of 10 Old 03-17-2014, 08:22 PM Thread Starter
No one has a thought on this?
post #3 of 10 Old 03-23-2014, 03:39 PM
big-daddy's Avatar
Swanys, I have a 2012 SS convert able, I had a local muffler shop remove the stock mufflers and replaced with stratght pipes. sounds great under some throttle, but still quiet otherwise due to the dual mode flappers. The owners manual says the fuse is in the fuse block in the trunk, position F8, I wanted to remove it to keep the flaps open, but there was no fuse or relay for the flaps as the manual indicated.
Big Daddy
Macon, GA
big-daddy is offline
post #4 of 10 Old 04-07-2014, 08:00 PM
dual mode exhaust
The flapper is at the exit end of the muffler. If you had the dual mode exhaust it went with the stock mufflers when you had them removed. If there was no fuse then I guess you did not have the dual mode exhaust system in the first place.
ThomasWarren is offline
post #5 of 10 Old 04-07-2014, 10:07 PM
Q'smuscle's Avatar
dual mode exhaust started with the 2013 year camaros! It's the NPP Dual mode exhaust!
Chevy's nothing else matters!
Q'smuscle is offline
post #6 of 10 Old 04-10-2014, 07:56 PM
Hotwheels's Avatar
I have dual mode exhaust maybe tomorrow I will look for the fuse, I have all the trunk apart.
When I first purchased it I could not believe how quiet the exhaust was.
Just found out my Camaro is:
#234 of 1524 Hot Wheels Camaro`s Produced in 2013.
Hotwheels is offline
post #7 of 10 Old 04-25-2014, 07:34 PM
How do I know if I have this on my car?
2013 Camaro 2ss
Hoytjr2013ss is offline
post #8 of 10 Old 04-25-2014, 07:51 PM
2013 Camaro 2ss
If you have the dual mode exhaust you will have 4 exhaust tips in the back instead of 2.
See my items on www.amazon.com
Seller Name: Muscle Car Memories
Vintage-Iron is offline
post #9 of 10 Old 04-25-2014, 08:16 PM
Cool thanks
2013 Camaro 2ss
post #10 of 10 Old 04-26-2014, 08:37 AM
I had the same exhaust on my Z06 and designed a remote to open or rather close the flaps, the car will start with them open. you can also buy a Mild to Wild switch. it was easy to do on the vette, not sure on the Camaro.
Herk14vertss is offline
