NEED HELP! nitrous on an LS3 - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 15 Old 05-24-2014, 05:04 PM Thread Starter
getnwetSS's Avatar
I just bought a wet nitrous kit for my camaro, I am only running a 50 shot and I was wondering if I had to adjust my ignition timing to run such a low shot. If so how and what is the best way? Thanks so much for your advice!
getnwetSS is offline
post #2 of 15 Old 05-24-2014, 05:13 PM
Do NOT run nitrous without a proper tune done by someone who knows what he is doing. If you run lean, you destroy your engine. Got a spare ten Gs lying around?
post #3 of 15 Old 05-24-2014, 05:21 PM Thread Starter
getnwetSS's Avatar
Do I need to get a programmer for them to do that and what is a good one to start with, I noticing all adjust timing.
post #4 of 15 Old 05-24-2014, 06:07 PM
Where are you? Someone on here will know a decent shop you can have tune your car.
300-500 is usually the going rate.
post #5 of 15 Old 05-24-2014, 06:36 PM
Usually with nitrous, a 50-75 shot without tuning is fine on a stock engine or an engine with bolt-ons. You have a 50 shot so you shouldn't have any problems. If you have an aftermarket cam or boost or other extensive mods done, then you will need someone to look at it. Just make sure the install is correct. And it never hurts to contact a performance shop for advice.
post #6 of 15 Old 05-24-2014, 11:23 PM Thread Starter
getnwetSS's Avatar
Thanks for the advice, I heard that if i stay at 75 or below I would be ok, I just want to make sure I don't have to retard the timing , book that came with the kit said 2 degrees but the 58x ignition system on the camaro should adjust itself?
post #7 of 15 Old 05-24-2014, 11:55 PM Thread Starter
getnwetSS's Avatar
Also I am located in Williamsburg VA
post #8 of 15 Old 05-25-2014, 07:37 AM
Yea rule of thumb is 2 degree retard for every 50 hp on a V8 engine. But like I said, lots of people get away with 50-75 and no tuning. But you also have to be safe. Just because some people get away with it doesn't mean you will also. So if you are any bit unsure, then contact a few speed shops for their advice.
post #9 of 15 Old 05-26-2014, 06:39 AM
MidlifeSS's Avatar
I would take it to a shop that has dealt with nos on ls motors.Better being safe than sorry.Nos can be safe if dealt with correctly.
MidlifeSS is offline
post #10 of 15 Old 05-26-2014, 08:05 AM Thread Starter
getnwetSS's Avatar
Do I have to buy a box or can they reprogram the stock ecu?
