CAI performance gains - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 29 Old 06-01-2014, 09:05 AM Thread Starter
I just saw a Youtube video done by two Australian's that ran; stock air box, cone filter, CAI box, no air box at all and one they made that was unusable on the the street. All of the air boxes showed poorer or equal at best performance on the dyno than the stock air box. It was a very interesting video. I know we all do this, all my previous Camaros and Vette it was the first thing I did, and an engine is just an air pump more in and more out makes more power. Have seen all the ads showing dyno results but has anyone actually seen results with just a CAI change?
Herk14vertss is offline
post #2 of 29 Old 06-01-2014, 10:09 AM
They are published on this site.
post #3 of 29 Old 06-01-2014, 05:39 PM
Cuz we all know the search functions on these forums suck! And I'm in a benevolent mood Here is a link to the results Ted @ JRE gleaned from his testing:
https://docs.google.com/spreadsheet/...VE&hl=en#gid=0
Which one? Depends on whether or not you want to re-tune the car or have to modify it to get the CAI to fit (fastlane & New Era etc)....
HINT: look closely at the CAI brand of intake, it got the best results without any tuning or having to mod the car to get it to fit....
post #4 of 29 Old 06-01-2014, 06:54 PM
83Hokie's Avatar
That's pretty much how I ended up with CAI, but I do have a small bit of buyers remorse ... I would be perfectly happy, except I added a hood that allows for air flow and I wonder if I would have gotten more air flow into the intake with one of the CAIs that has an open top vice the enclosed box ... I'm good with what I got, but I do wonder (and, of course, I don't think there is a comparison out there with my hood versus the stock hood)
83Hokie is offline
post #5 of 29 Old 06-02-2014, 05:15 AM
MidlifeSS's Avatar
I have the CIA brand and a zforce ram air hood and I took the glass out of the cover.I have a rubber seal that seals it between the hood and air box.You can also add a adm scoop to get a added gain in hp.
MidlifeSS is offline
post #6 of 29 Old 06-02-2014, 09:06 AM
There is a rather large piece of plastic behind the grill (right behind the SS emblem) that blocks a LOT of flow to the airbox AND AC/Rad. I removed mine (2 push pin type fasteners), trimmed it and reattached just the face of it so I wouldn't see the silver frame part thru the grill. I inserted some closed cell foam to block a now open area that would allow air to travel downward vs into the airbox. This does require removal of the nose of the car but is well worth it...
Aside from the improvement in power for me, my running temp (coolant) dropped 4 degrees and my SC is barely warm after blasting around, even on 90 degree days....
post #7 of 29 Old 06-02-2014, 04:32 PM
Here is something I posted on another forum that might be of interest here. Only IAT and MAP data, not HP, but might still interest some of you.
Below is a PDF file of some IAT Data I collected with a Cold Air Inductions intake and a Vararam Tune Model intake at the drag strip. Nothing fancy or scientific about the methodology, I just used the Ambient T, RH and Barometric P from the track's weather observations posted on Drag Times. The IAT numbers were retrieved from the car's ECM with EFILive data logs that I collected during my runs. No system in place as far time between runs, cool down strategy (hood open, hood closed, etc.), haphazard is the best way to describe it. This is raw data and I will not attempt to influence you with my conclusions. You'll have to look at the data and draw your own conclusions. Again, totally unscientific in methodology.
jbrown13 is offline
post #8 of 29 Old 06-02-2014, 06:35 PM
83Hokie's Avatar
I like how this sounds, but I am deathly afraid of removing my front end ... maybe one day down the road, but not yet
83Hokie is offline
post #9 of 29 Old 06-02-2014, 06:40 PM
83Hokie's Avatar
adm scoop? I may have seen that somewhere, but don't recall anything about it ... I did wonder about doing something like you said with the CAI cover ... I have a RK Sport hood and I think there is air flow right to that point ... I might have to look at rigging something there ... what kind of rubber seals did you use?
83Hokie is offline
post #10 of 29 Old 06-03-2014, 01:58 AM
If you're talking about the video I think you're talking about then I would pay those two idiots absolutely no mind. Those guys were complete numbskulls and had no idea what they're talking about. If I remember correctly they rigged up an intake that looked like crap, their testing methods were impractical, they spent the whole video acting like fools, and their testing site was complete BS. Even the vehicle they used was a complete joke. Even if their test was accurate, able to be duplicated, and credible, you still can't draw the conclusion they drew as applicable to every vehicle.
Intakes have been tested for decades. They've been proven to work time and time again. There has been testing from manufacturers, magazines, and third parties that have all proven the same thing. And even those who don't use dynos have proven results at the track. I'll admit that the manufacturers always exaggerate the gains for marketing purposes. However the actual results speak for themselves. Vehicle manufacturers fashion the intakes for specific reasons. Engine noise control, emissions, fuel economy, filtering harmful debris, etc are all factored in. Aftermarket companies make intakes specifically for improving performance. A proper cold air intake will outperform a stock intake in almost all cases.
The other night I datalogged. It was like 68 degrees F and my IATs stayed consistently at ambient to 3-5 degrees F warmer than ambient while the car was moving at 50 mph. While stopped for a few minutes they crept up to 90 degrees F but went right back to ambient once I started moving again! I have Vararam tune model.
