boost gauge HELP - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 5 Old 06-18-2014, 06:44 PM Thread Starter
boost gauge HELP
Im trying to install a boost gauge on my car and cant find a fuse that is key hot NEED HELP
evilcamaro is offline
post #2 of 5 Old 06-18-2014, 07:44 PM
I did mine from one on the fuse block at the left end of the dash... Open the drivers' door, pull the panel and check em out.
post #3 of 5 Old 06-19-2014, 04:26 AM
I could be wrong but all of those fuses are hot at all times. If he is looking for a source that is hot only with the key in the "On" position, then I think he has to look elsewhere.
post #4 of 5 Old 06-19-2014, 08:36 AM
It's been awhile since I installed mine but I know I did not run the power wire from the engine bay and I don't "splice" into *****. That leaves the fuse block on the end of the dash....
OP, if you can't find what you are looking for, let me know and I'll take a look at mine again...
post #5 of 5 Old 06-19-2014, 08:47 AM
If you don't already have the gauge, look @ https://www.facebook.com/dashdaq
