Need help ASAP!!! - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 5 Old 08-03-2014, 12:20 PM Thread Starter
GroundSpeed's Avatar
Need help ASAP!!!
I have a 5.5hr drive ahead of me like now and I just noticed the upper rad hose looks like it's about to blow off. Is this normal? I've never noticed it before and want to make sure it's safe to drive.
GroundSpeed is offline
post #2 of 5 Old 08-03-2014, 01:50 PM
Here are what mine look like. You may just need to depress the clip and then push your hose up to the tab. It should be fine if you do that.
ID:	40097   Click image for larger version
post #3 of 5 Old 08-03-2014, 03:51 PM Thread Starter
Thanks Chapel I moved it up to where you have it. It sits a lot better now
post #4 of 5 Old 08-03-2014, 08:34 PM
No problem man. Have a safe trip. And I'd recommend keeping an eye on it just in case it starts to slip out again. And good for you for doing a spot check before a long trip. I should do that more often but I'm too lazy.
post #5 of 5 Old 08-04-2014, 05:01 AM
+1
