2010 2SS Stainless Power - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 29 Old 10-02-2014, 03:11 PM Thread Starter
MickGIS's Avatar
I spotted a set of Stainless Power, with high flow cats to connect to stock exhaust for $687.74 (w/coupon and free shipping) from AutoAnything.com. Folks seem to like them but like anything there has been an issue now and then. The latest I read was gaps in the flange weld. Has anyone had any experience with them or have heard anything elase good or bad? I know a tune will get the most out of them but will the engine throw any error without a tune?
MickGIS is offline
post #2 of 29 Old 10-02-2014, 03:39 PM
As long as the O2 sensors are NOT relocated farther away from the cats, use extenders or eliminated completely, it should not throw any codes.
post #3 of 29 Old 10-02-2014, 04:22 PM
83Hokie's Avatar
eliminate the O2 sensors or the cats?
83Hokie is offline
post #4 of 29 Old 10-02-2014, 06:55 PM
O2 sensors
post #5 of 29 Old 10-16-2014, 11:19 AM Thread Starter
MickGIS's Avatar
The Stainless Power LT headers do use an extended wiring harness for the O2 sensors, from the AutoAnything.com website:
Features
  • Replace restrictive factory exhaust manifolds with budget-friendly Stainless Power Headers
  • Tuned for your specific year, make and model vehicle
  • Maximizes horsepower, torque and throttle response
  • TIG welded from high-quality T304 stainless steel
  • 3/8" thick T304 stainless steel header flanges
  • CNC laser-cut flanges and mandrel-bent tubes
  • Formed merge collectors and welded-in merge spikes
  • Welded O2 sensor bungs (most vehicles)
  • Includes extensions for front O2 sensors (most vehicles)
  • Bolt-on design uses factory locations for straightforward installation
  • Each header has the Stainless Power badge TIG-welded in place
  • Install-ready kit includes headers, bolts, RTV hi-temp silicon and clamps
  • Couple your headers with a Stainless Power Exhaust System for a budget-friendly performance package
  • Your Stainless Power Headers are backed by a 2-year warranty
MickGIS is offline
post #6 of 29 Old 10-24-2014, 06:18 PM
christianchevelle's Avatar
I have stainless power heads with highflow cats and they are great the welds are fine, I do have a 2013 with electric power steering and know many brands of headers have interference fit problems with the older style Camaros power steering/column and have to have them dented a little by the shaft...... I bought mine from Maryland speed for $712 with cats free shipping. I did have to have the CEL eliminated due to slowed response from the front 02 sensor being farther down stream meaning it sent: delayed response code to the ECU..... You will want the headers to have a new set of g.m. exhaust metal exhaust gaskets for the headers..do not use the silicone junk and the gaskets are only like $20.00. I polished mine with a buffing head and stainless polish stick I got at harbor freight before install and now they have a nice shine with the Champagne color cooked in. They do make the car so much louder, and they do not require a harness extender that I know of as I did not need one. Good luck
christianchevelle is offline
post #7 of 29 Old 10-25-2014, 05:31 AM
ModernCamaro.com Sponsor
Tampa Tuning's Avatar
They are a great budget header system. That's why I sell them.
Tampa Tuning is offline
post #8 of 29 Old 10-26-2014, 04:32 PM Thread Starter
MickGIS's Avatar
Well I took the plunge and ordered the "Stainless Power" LT w/cats for $687.74 delivered.
Should I get a new set of gaskets or can I reuse the stock gaskets?
Update: Oops I just reread the post by christianchevelle who said to get new gaskets, where did you get them?
MickGIS is offline
post #9 of 29 Old 10-28-2014, 07:33 AM
You can re-use the old gaskets. I re-used mine and there was no problem. Most of us who do headers re-use the stock gaskets. If you do get new ones, then get them from the dealer. Do not get aftermarket gaskets.
post #10 of 29 Old 10-28-2014, 09:25 AM Thread Starter
MickGIS's Avatar
Rats, last night I ordered new gaskets from newgmparts.com, I'll try to cancel and call the dealer.
MickGIS is offline
