Experences With Underdrive Pulleys - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 18 Old 12-15-2014, 02:31 PM Thread Starter
MickGIS's Avatar
I have read many posts on the pros and cons of underdrive pulleys here and on Camaro5 and have determined that these two are of interest:
Fluidampr Harmonic Damper vs SLP Balancer/Underdrive Pulley
What are your experiences with them and why do you prefer one over the other?
MickGIS is offline
post #2 of 18 Old 12-15-2014, 05:34 PM
The accessories were designed for a specific RPM range. I'd leave it alone...unless you know more than GM's engineering team.
post #3 of 18 Old 12-15-2014, 06:54 PM
S.Bretz's Avatar
From my experience (with other cars) its a lot of investment for a minimal gain.
Though the fluid filled dampeners do provide better harmonic absorbsion than the OEM rubber does and is a good idea if you twist the engine high in the rpms for extended periods of time (ie road racing).
S.Bretz is offline
post #4 of 18 Old 12-16-2014, 08:45 PM
Not to contradict anyone here, everyone here is very knowledgeable. I did the mod. I have the SLP UDP. I've had it on my car for about a year and a half. I have had no problems with it. No cooling problems at all. I was DDing my car during a few weeks of 90-105 degree days in stop and go traffic and I had no cooling or electrical/charging issues. No problems whatsoever.
But I will advise you of this...when you, or if you, do the swap, make sure you go to a GM parts store (at a dealership) and get a brand new crank pulley bolt. The old one will be no good once it comes out. Don't even try to use it.
And also, make sure you, or whoever does the install, follow the torquing procedure to the letter. Do not skimp out, do not take a short cut, do not skip it at all. If you take the car to a shop to have a mechanic do it, then before you go, download and print out the torque procedure. Bring it with you, give it to the mechanic, and watch him do it exactly as it states and shows. I hate to sound all dramatic, but it is important that the torque procedure is followed. I can all but assure you that everyone that had problems was due to improper seating and torquing of that bolt. Outside of that, I am sure you'll have no problems.
post #5 of 18 Old 12-16-2014, 08:48 PM
Here is the installation manual from SLP for their pulley. A different company may have a different set of instructions...
http://www.slponline.com/instructions/100230A.pdf
post #6 of 18 Old 12-17-2014, 04:25 PM Thread Starter
MickGIS's Avatar
Thanks Chapel for you well thought out, unemotional responses.
Yes, the torquing procedures seem involved and from what you said critical to a successful install.
I noticed in the install instructions in step 2
"2 Install a suitable flywheel holding tool."
I looked around and all I found mentioned was a fitting that replaced the starter and keeps things from turning. I wasn't able to find one available for sale online for under a $100, this may be a show stopper for me. Maybe one of the auto parts stores have ones they rent or allow use of, I'll check around.
MickGIS is offline
post #7 of 18 Old 12-17-2014, 04:52 PM
Hooray for Chapel!
post #8 of 18 Old 12-17-2014, 05:25 PM Thread Starter
MickGIS's Avatar
Well I called both AutoZone and O'Reilly's Auto Parts and neither had a flywheel holding tool for sale or rent.
If anyone has an idea please post it here.
MickGIS is offline
post #9 of 18 Old 12-17-2014, 09:19 PM
Try GM, they should have what you need. It might cost you a bit of money tho. But wherever you go for the install, they should have it and every other tool you'll need. If I were you, I'd check the rates at a shop for the install and then compare that to the price of the tool. I can't see any shop charging more than $100 max. So if the tool comes out to more than that, then just have it professionally done...even more so if you've never done something like this before.
Or you can try this dude on LS1 tech forums. Here is the link:
Flywheel flexplate holders - LS1TECH
See if he still has them. It should work on your engine.
post #10 of 18 Old 12-19-2014, 07:38 PM Thread Starter
MickGIS's Avatar
I asked the Guy on LS1Tech and he said:
"Yes I have them. $35 Shipped in the USA $50 to canada..."
Thanks for the tip.
MickGIS is offline
