2014 Auxiliary gauges installation HELP - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 6 Old 02-27-2015, 09:02 PM Thread Starter
427cubicinches's Avatar
Hey guys, trying to install Auxiliary gauges in 2014 SS.
Kit came with a 3 wire hook up for the gauges, red, black and green.
There are 2 latches that have to be released on the fuse block to pull it out to splice into battery wire on cavity 2 for the RED battery wire for the gauges.
I tried for about an hour but can't get them released.
The latches are on the bottom of the fuse block.
Any help would be much appreciated. Thanks.
427cubicinches is offline
post #2 of 6 Old 02-28-2015, 09:10 AM
I'm confused. The GM gauges are plug-n-play at a connector near the shifter, no need to be messing with the fuse block or wiring. So this means you went another route for gauges?
Anyway, that fuse block "unsnaps" vs tabs that release. Just pull it out starting at the lower corner closest to the firewall. They are very strong snap-ins so some serious effort may be required. I have found that the top ones are the hardest actually....
post #3 of 6 Old 02-28-2015, 09:44 AM Thread Starter
I was confused as well when i picked up the GM gauges.
I read about the plug-n-play near the shifter and also saw a video on it.
The 2014-15's now seem to have a different hook up from the 2010-13's.
Instructions that came with gauges:
Thanks, Bob
post #4 of 6 Old 02-28-2015, 10:21 AM
Holy [email protected]! Now I am wondering if they may have changed the way the fuse block is mounted!
post #5 of 6 Old 02-28-2015, 10:48 AM Thread Starter
I would have MUCH preferred the plug-n-play.
It looks like the fuse block needs to go rearward but i am failing to get it to go one way or the other!
Many Thanks for your input, Bob
post #6 of 6 Old 03-03-2015, 12:17 AM Thread Starter
Having a problem releasing the fuse block out of this 2014.
Any more suggestions?
