I like the AFM idea - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 19 Old 07-25-2008, 08:20 PM Thread Starter
Dom
I like the AFM idea
I know most are complaining about the lower power of L99, and AFM, but I like it. Why waste gas when you're not accelerating? Also L99 is identical internally so it's most likely the same power as the LS3. Just like the vette LS1 was 350hp and the identical fbody LS1 was 305hp. I'm just going to call it LS3 w/ AFM.
Dom is offline
post #2 of 19 Old 07-25-2008, 08:35 PM
brandonppr's Avatar
I like AFM as well. I doubt there are really any difference in HP outputs and if there are I do not doubt that it could be fixed with a tune. Besides the quarter mile times were about the same anyway.
The only thing I would ask for is Flex fuel option like on the 6.2L in the Escalade.
brandonppr is offline
post #3 of 19 Old 07-25-2008, 09:16 PM
I agree...
I am just hoping the tuner's (Lingenfelter, Calloway, Mallet, et. al.) offer packages for the L99 (without disabling the AFM).
They already have packages for the LS3. Any thoughts on the likelihood of tuner packages for the L99?
petervegas is offline
post #4 of 19 Old 07-25-2008, 09:16 PM
See You On Course
CUONCRS's Avatar
I was looking forward to that as well, and considering that GM has the tech, and they were pushing to make their models al flex-fuel, I'm kinds surprised it isn't. Not a deal breaker, but would have been nice. Only muscle car to offer it would have been an advertising home run as well.
2010 Stock IBM 2SS/RS
CUONCRS is offline
post #5 of 19 Old 07-25-2008, 09:21 PM
brandonppr's Avatar
I am sure they will be available. AFM can be turned off and on with programs like HPtuners. I'm sure HP tuners will have it availiable as soon if not before it hits the showrooms.
post #6 of 19 Old 07-25-2008, 09:25 PM
afm is a good idea but it needs to go further...it only works at hiway speeds and it takes a lot of cruising to make a difference in the fuel economy..that's why the epa numbers aren't different between the two v8's...the epa cycle is too short to reflect the fuel savings attributable to afm.
the big problem with afm is it doesn't work around town when you're idling for exampe...that's when a v8 is a real killer for fuel economy, not on the hiway..i would live with a little shudder if i could cut off half thecylinders sitting at a light.
jackg
06 sts6
justgreat is offline
post #7 of 19 Old 07-25-2008, 09:29 PM
See You On Course
CUONCRS's Avatar
That's where a hybrid is the best, too. Pull up to the light and the engine shuts off. Hit the gas, and the engine starts and runs. Wish they could make that practical for ALL cars. That would save a lot of gas overall.
CUONCRS is offline
post #8 of 19 Old 07-25-2008, 09:40 PM Thread Starter
Dom
jackg
06 sts6
I thought it activated whenever you coasted or idled. I don't know much about it, but I just assumed that.
Maybe instead of tuning it out, we can tune it in even more. I'd like to have it turn on whenever I'm not on the gas. When I'm stopped, braking, in reverse, below 2k coasting. I really don't use my LS1 to it's full potential. Most of the time I'm commuting around town and it hasn't seen WOT in a long time.
Dom is offline
post #9 of 19 Old 07-25-2008, 09:44 PM
Good point, I totally agree!
Norah is offline
post #10 of 19 Old 07-25-2008, 09:45 PM
Jonz5GEN's Avatar
So who's buying a 400hp Prius?
Jonz5GEN is offline
