Gen6 Camaro Radiator Expansion Tank - ModernCamaro.com - 5th Generation Camaro Enthusiasts
post #1 of 2 Old 09-22-2016, 04:04 PM Thread Starter
Granatelli Motor Sports is proud to introduce replacement radiator expansion tanks with built in reservoir for all 2016 & 2017 model year (Gen 6) Camaros as well as Cadillac ATS and CTS model vehicles including the V-series! The Granatelli unit is uniquely designed and intended to be a direct replacement for the unsightly factory component, adding a much needed appearance upgrade. Best of all, you no longer have the unsightly plastic tank that is prone to discolor, wear out and leakage due to cracking. This gives the end user that much needed pieces of mind knowing they will be trouble free for the life of the vehicle. The Granatelli tank comes in wrinkle black (P/N 500201B), polished (P/N 500201P) or wrinkle black with GMS logo (P/N 500201BL). They even work with the new ZL1 Camaro with the coveted 630+ horsepower LT4 engines. The Granatelli hand built 6061-t6 reservoir is a simple remove and replace installation using all factory hardware, you should not even loose a drop of original coolant. All the factory hose connections are a direct cross over making installation no more than 30 minutes. The Granatelli distinctive design mimics the same shapes and angles of the OE plastic tank ensuring a simple remove and replace installation.
The Granatelli Motor Sports replacement radiator expansion tanks with built in reservoir for all 2016 & 2017 model year (Gen 6) Camaros as well as Cadillac ATS and CTS model vehicles including the V-series are available wherever Granatelli Motor Sports products are sold.
(P/N 500201B) - Wrinkle Black, (P/N 500201P) - Mirror Like Polished or (P/N 500201BL) Wrinkle Black with GMS logo.
Granatelli Sales is offline
post #2 of 2 Old 09-27-2016, 02:41 PM Thread Starter
55 units sold in the first week selling fast
