I am selling my 1967 Camaro with SS350 trim. I have owned this car since 1981 and it underwent a 15 year restoration before I drove it for the first time. I has been driven sparingly since then and I have included all info regarding replaced parts. I have pictures and receipts documenting the whole restoration process. Asking $38,500 USD Contact me for more info.
[email protected]
- NEW HEATER CORE G.M. NOS
- NEW BODY MOUNTS
- NEW TINTED WINDSHIELD
- NEW GAS TANK G.M. NOS
- NEW FUEL SENDING UNIT G.M. NOS
- NEW WEATHER STRIPPING AND WINDOW BRUSHES
- NEW FRONT FENDERS G.M. NOS
- NEW FRONT INNER FENDERS G.M. NOS
- NEW FLOOR PANS BOTH SIDES FRONT TO BACK
- NEW FULL REAR QUARTERS G.M. NOS, LEADED IN
- NEW INNER AND OUTER WHEEL WELLS
- NEW FULL TRUNK PAN AND SIDE PANELS
- NEW CARPET
- NEW SCUFF PLATES
- NEW ROOF LINER, VISORS AND SIDE PANELS
- NEW EMBLEMS, LOCKS, DOOR HANDLES AND BOW TIE MIRROR G.M. NOS
- NEW B.F.G. T.A.'S 215/65/15, 255/60/15
- 15" RALLYE WHEELS - VETTE ON REAR
- NEW SHOCKS, BRAKES- SHOES, LINES AND MASTER CYLINDER
- SWAY BAR , BUSHING AND PINS
REAR END (SAND BLASTED AND PAINTED)
- 12 BOLT POSI CODE PR (3.31 POSI), NOW RICHMOND 3:73
- MULTI LEAF REAR SPRING
BLOCK
CASTING 3914678 1968 327 HIGH PERFORMANCE
BORED 30 OVER
ENGINE KIT, TANKED, HONED AND CRANK POLISHED
4 Spd. Saginaw @ NEW H.D. 11" CLUTCH
HEADS
350 194 INTAKE, 150 EXHAUST
3 ANGLE VALVE SEATS
TEFLON P.C. VALVE SEALS
76 CC. COMBUSTION CHAMBER
CAMSHAFT
GENERAL KINETICS
.438" LIFT
284 DEG. DURATION
EDELBROCK INTAKE
TORKER, SINGLE PLANE
CARB.
HOLLEY 780 DUAL FEED, VACUUM SECONDARY
PISTONS
SPEED PRO, FORGED FLAT TOP
11:1 COMPRESSION
RINGS
SPEED PRO SINGLE MOLY 5/64" COMPRESSION
ROCKERS
SELF ALIGNING G.M.
SPRINGS
G.M. HIGH PERFORMANCE SINGLE
125 LBS. SEAT PRESSURE
PUSHROD
NEW BALL TYPE G.M.
OIL PUMP
G.M. HIGH PRESSURE OIL PUMP
TIMING CHAIN
SPEED PRO HIGH PERFORMANCE ROLLER CHAIN WITH STEEL GEARS
GASKETS
FEL PRO TEFLON PERFORMANCE FOR HEAD AND INTAKE
HEADERS
CERAMIC POWDER COATED
INTERIOR
NEW BLACK AND PARCHMENT DELUX INTERIOR FROM CAMARO SPECIALTIES IN(2007)
[email protected]
- NEW BODY MOUNTS
- NEW CARPET
- NEW SCUFF PLATES
BLOCK
BORED 30 OVER
HEADS
3 ANGLE VALVE SEATS
CAMSHAFT
GENERAL KINETICS
.438" LIFT
284 DEG. DURATION
EDELBROCK INTAKE
CARB.
PISTONS
11:1 COMPRESSION
RINGS
ROCKERS
SELF ALIGNING G.M.
SPRINGS
PUSHROD
NEW BALL TYPE G.M.
OIL PUMP
TIMING CHAIN
GASKETS
HEADERS
INTERIOR
