1 - 3 of 3 Posts
In 1967 here is what the Camaro cost and options. wow have times changed.:eek:
1967 Factory Options
RPO Description Qty Retail
Camaro Sport Coupe, 6-cylinder 53,523 $2,466.00
Camaro Convertible, 6-cylinder 5,285 2,704.00
Camaro Sport Coupe, 8-cylinder 142,242 2,572.00
Camaro Convertible, 8-cylinder 19,856 2,809.00
AL4 Front Seat, Strato-back (bench) 6,583 26.35
AS1 Belts, standard type front shoulder 477 23.20
AS2 Headrests, Strato-Ease 2,342 52.70
A01 Soft Ray tinted glass, all windows 34,725 30.55
A02 Soft Ray tinted glass, windshield only 81,998 21.10
A31 Power Windows 4,957 100.10
A39 Belts, custom deluxe front and rear 51,247 6.35
A67 Seat, rear folding 17,993 31.60
A85 Belts, custom deluxe front shoulder 894 26.35
B37 Floor Mats, color-keyed front/ rear 23,747 10.55
B93 Guards, door edge 37,964 3.20
C06 Top, power (convertible) 11,783 52.70
C08 Vinyl Roof Cover (coupe) 52,455 73.75
C48 Heater and Defroster Delete (credit) 2,201 -31.65
C50 Defroster, rear window (coupe only) 7,031 21.10
C60 Air Conditioning 28,226 356.00
C80 Positraction Rear Axle 31,792 42.15
C94 Axle, optional 3.31:1 ratio 1,177 2.15
C96 Axle, optional 3.55.1 ratio 6,322 2.15
C97 Axle, optional 2.73:1 ratio 539 2.15
D33 Mirror, left outside remote control 8,630 9.50
DSS Console with floor-mount shifter 129,477 47.40
D91 Band, front accent 24,370 14.75
F41 Suspension, special purpose front/rear 5,968 10.55
H01 Axle, optional 3.07:1 ratio 560 2.15
H05 Axle, optional 3.73:1 ratio 2,281 2.15
J50 Power Brakes, front and rear drum 24,549 42.15
J52 Power Brakes, front disc, rear drum 14,899 79.00
J56 Brakes, h/d front disc, met. rear drum 205 105.35
J65 Brakes, front and rear drum, metallic 1,217 36.90
K02 Fan, temperature controlled (V8 only) 2,375 15.80
K19 Air Injector Reactor (required CA) 34,096 44.75
K24 Ventilation, engine closed positive 34,503 5.25
K30 Speed and Cruise Control 305 50.05
K76 Generator, 61-amp Delcotron 136 21.10
K79 Generator, 42-amp Delcotron 362 10.55
L22 Engine, 2SOci/155hp Turbo-Thrift 6-cyl 38,165 26.35
L30 Engine, 327ci, 275hp Turbo-Fire V8 25,287 92.70
L35 Super Sport, with 396ci, 325hp engine 4,003 263.30
L48 Super Sport, with 3SOci, 295hp engine 29,270 210.65
L78 Super Sport, with 396ci, 375hp engine 1,138 500.30
M11 Shift Lever, floor mounted 12,051 10.55
M13 Transmission, special 3-speed manual 681 79.00
M20 Transmission, 4-speed wide range man. 45,806 184.35
M21 Transmission, 4-speed close ratio man. 1,733 184.35
M35 Transmission, Powerglide automatic 122,727 184.35
M40 Transmission, Turbo Hydra-Matic auto 1,453 226.45
N10 Exhaust System, dual 6,722 21.10
N30 Steering Wheel, deluxe 30,967 7.40
N33 Tilt Steering Column 7,980 42.15
N34 Steering Wheel, walnut-grained plastic 8,065 31.60
N40 Power Steering 92,181 84.30
N44 Special Steering, quick ratio 6,155 15.80
N61 Dual Exhaust with deep-tone mufflers 13,748 21.10
N96 Wheel Covers, mag style 6,630 73.75
PQ2 Tires, 7.35x4 2-ply nylon white stripe 10,913 52.00
PW6 Tires, D70~4 2-ply nylon red stripe 8,330 62.50
P01 Wheel Covers, bright metal 137,163 21.10
P02 Wheel Covers, simulated wire 6,577 73.75
P12 Wheels, (5), 14x6 3,667 5.30
P58 Tires, 7.35x14 2-ply whitewall 138,998 31.35
T60 Battery, heavy-duty 7,964 7.40
U03 Horn, tri-volume (coupe) 1,580 13.70
U15 Speed Warning Indicator 3,698 10.55
U17 Special Instruments (req V8 & console) 27,078 79.00
U25 Light, luggage compartment 24,787 2.65
U26 Light, underhood 22,965 2.65
U27 Light, glovebox 11,032 2.65
U28 Light, ashtray 25,538 1.65
U29 Lights, courtesy (coupe) 23,691 4.25
U35 Electric Clock (included with RPO U17) 13,185 15.80
U57 Stereo Tape System 2,746 128.50
U63 Radio, AM pushbutton 174,021 57.40
U69 Radio, AM-FM pushbutton 6,232 133.80
U73 Antenna, manual rear mount 32,223 9.50
U80 Speaker, rear seat 27,701 13.20
V0l Radiator, heavy duty 6,190 10.55
V31 Guards, front bumper 35,154 12.65
V32 Guards, rear bumper 35,029 9.50
Z21 Style Trim Group 79,016 40.05
Z22 Rally Sport Package 64,842 105.35
Z23 Interior, special 74,648 10.55
Z28 Special Performance Package (coupe) 602 358.10
Z87 Custom Interior 69,103 94.80
Supporter of common sense
D91 Band, front accent 24,370 14.75F41 Suspension, special purpose front/rear 5,968 10.55
L48 Super Sport, with 35Oci, 295hp engine 29,270 210.65
L78 Super Sport, with 396ci, 375hp engine 1,138 500.30M11 Shift Lever, floor mounted 12,051 10.55
Looks like the Camaro white book :D
to the best of my knowledge, I marked our Camaro's options in bold above, today our car is worth about $50K completed. We need to get off our asses :lol:
1 - 3 of 3 Posts
