1 - 8 of 8 Posts
40mm? Really?
40mm? Really?
I looked at the spec when i had the V6, the V6 sat 40mm above the v8. This meant using V8 loweing springs I would get close to a 2" drop on a V6. The swap worked great so when I traded my V6 in I had my original V6 shocks re-installed and the lowering shocks put on my V8.
Is this a set of 4 (front and rear) or 2 (just front springs). I have a 1LT on order w/grd effects and would like to lower it. Where are you located?
I'm in kissimmee fla......:black5thburn:
Discussion Starter #5
These are a set of 4 front and rear. I am located in nothern california.
I want to buy the springs. What would it cost to ship to me??? Are they damaged at all. You wrote that you had them installed in your car before...How hard is it to install the fnt and rear springs on a home garage floor..Have plenty of tools and experience with restoring my 1st gen camaro but i haven't done any work on the 5th gen camaro.. Looking for time frame and will it need alignment when complete....Are they direct repacements; easy swap out and swap in. Give me total cost for springs and shippig.....
Discussion Starter #7
Rich
Springs are on hold for you. I will get shipping cost tonight. I need to way them and get post office quote What is your zip code?
On install I had big o tires do my install I belive it cost me 100 to have them installed and aligned. ON htese springs they have less then 30 miles on them. When I bought my SS new it went into the shop next day and had my after market springs installed and these were pulled off. ANy questions, give me a call be gald to answer all of them. I am sending you a private PM with my phone number. I can call you if you do not have a unlimited calling plan.
Scott
1 - 8 of 8 Posts
