1 - 3 of 3 Posts
My convertible top will go down about halfway then just stop, motor cuts out. Will go back up after the stoppage with no issues. Any thoughts on what the heck is going on?
Might be the your motor, its hard to say but most likely the issue or something is stuck at that half way point (check to see if it always stops at the same spot).. your switch is working, witch is good.. Sorry I cant be more helpful
It is about the same spot everytime and if you push on the top you can force it down further.
1 - 3 of 3 Posts
