1 - 3 of 3 Posts
installing some diffuser fins i made to the lower valance.
there are some T20 torx screws to remove from the bottom and side of the valance.
on each side under the car where the mufflers are, there are two T20 screws to remove. lucky for me, i removed my mufflers.
at the rear of the back tire behind the inner liner, there are two rivets that will need to be drilled out.
there are some molded tabs that are used to hold the valance to the bumper cover. the side ones you can press with your fingers and pull the valance off the fenders.
the tabs along the bumper cover, you can use a flathead scredriver or plastic prybar and slide in to press down on the tab and pull out.
Discussion Starter · #2 ·
something i noticed was how floppy the bumper was. i noticed the absorber is just clipped on. so, i used self tapping screws and mounted it to the car to keep it from moving around. now, it's solid.
Discussion Starter · #3 ·
finished up today
1 - 3 of 3 Posts
