Was not broken in properly it sounds like (dealers like to say things are normal or "OK" when they are not for some reason).
If you take it out and look at the flywheel portion and pressure plate there will be hot spots and divots worn in. Most likely the original owner slipped the clutch too much when it was new. Takes a few heat cycles to properly bed the friction disc to the flywheel and pressure plate.
