1 - 20 of 24 Posts
So, when I went to test out the G8 a while back, I noticed that there was an annoying Airbag status light that stays on if there isn't a passenger in the right front seat. Will the Camaro have such a warning light or not? Just wondering. Thanks!
MIKE
Discussion Starter · #4 ·
I knew it would be in there, but I had to ask.
So I went back and looked at the post from OctaneZ28 about the Camaro driver's seat pic and you can plainly see the airbag light up there in the center headliner. I guess it won't be too bad. Usually, most people who have gotten annoyed by the light just cover it up or take it out completely.
lol i just looked at that thread and thought of the same thing!
Can somebody please en'lighten' me as to why you would even need a light to warn of a disabled airbag for an empty seat? I'm assuming the light goes out when a passenger above the minimum weight sits in the seat and enables the airbag.
It's more like an ON/OFF indicator.
Showing small amber "ON" or "OFF" on a small display.
Crappy picture of one from an Impala:
I'm not one to argue with engineers posessing major credentials, but it seems redundant to tell you the air bag is 'ON'. If it's an out of the ordinary situation, like a malfunction, I could understand the MIL.
Airbags should always be "ON". If its turned off by user or not enought weighti n the seat or whatever else might trigger it, then the light should come on to alert you.
The light really isn't a problem. At least if it is mounted in a decent location. I can see how the solstice location would be annoying. Here is the location in the Mustang. I dont notice it at all now. (It is the blank spot to the right of the hazard switch.)
1 - 20 of 24 Posts
