1 - 8 of 8 Posts
Vehicle: 2010 Camaro SS
Price: 65,000 OBO
Odometer Mileage: 29,821
VIN: 2G1FT1EWXA9141016
The vehicle was primarily used for show, making an appearance at the PRI and taken out on the Hot Rod Power Tour. The engine built by Katech currently has less than 500 miles and was tuned by Vector Motorsports (Dyno Graph available). The engine was originally dyno’d at Katech on their engine dyno at 14.7PSI to make 1000CHP before the installation into the vehicle.
Below are the specifications on the very extensive and custom build.
Engine Specs:
436 CID LS3 built by Katech Engines
Block: RHS; 4.165: x4
Heads: Chevrolet LS3, CNC Port and Polish by Katech
Engine Bearings (Main and Rod): Clevite
Pistons/Piston Rings: Diamond / Top Seal
Compression Ratio: 9.5:1
Connecting Rods: Callies
Crankshaft: Callies
Camshaft: Comp Cams
Valves: INTAKE: GM LS3, EXHUAST: Ferrea Super Alloy
Valvesprings: PSI
Lifters: Comp Cams
Timing Chain: Hutton
Crank Damper: ATI
Oil Pump: Katech Modified LS3
Be Cool Radiator with Single Spal Fan***
***The vehicle does get hot. If driving daily or in traffic it is suggested another fan be added.
Boosted Stuff:
Turbochargers: Twin Borg Warner S366S Turbocharger (Specs: 66/73 .88A/R)
Intercooler and Piping: Custom Fabricated by Vibrant Performance
Exhaust Manifold: Twin equal length turbo manifolds custom fabricated by Vibrant Performance
Wastegates/Blow Off Valve: Twin Tial Wastegates, Tial Q BOV
Fuel System:
Injectors: Deatschwerks 1000cc/min
Fuel Pump: Aeromotive Stealth Eliminator In-Tank
Fuel Pump Control: Aeromotive Fuel Pump Controller
Fuel Pressure: Aeromotive Adjustable Fuel Pressure Regulator
Fuel Rails: Aeromotive LS3
Intake: FAST 106 Intake Manifold
Powertrain:
Transmission: Stock
Driveshaft/Axles: Stock
Differential: Stock
Clutch: Exedy Hyper Single
Chassis/Driveline:
Brakes: Stop-Tech BBK
Suspension: Eibach Coilovers
Wheels: HRE Custom Wheels
Rear Tires: Michelin Pilot Super Sport ZP
Rear Size: 335/25ZR20
Front Tires: Michelin Pilot Super Sport
Front Size: 275/30ZR20
Exterior Modifications:
Custom Widebody/Ground Effects Kit done by HPP (6” wider)
Custom Paint done by HPP (Red/Silver) **Car currently wrapped in Flat Black**
Interior Modifications:
Fuse panel relocated to glovebox
AEM Gauges (Held in Glovebox): Tru-Boost (30-4350), Oil Pressure (30-4406), UEGO Failsafe (30-4900)
Videos Featuring Camaro:
https://www.youtube.com/watch?v=_18IL7vRTmU
https://www.youtube.com/watch?v=uhF5YzV3sfo
https://www.youtube.com/watch?v=tqOgs4XQo-E
CONTACT
Email: [email protected]
Phone: 248-632-1263
Discussion Starter #2
Here are photos.
...you may want to become a vendor before you start selling on here.
...just a thought.
Parasite reported.
"Be Cool Radiator with Single Spal Fan***
***The vehicle does get hot. If driving daily or in traffic it is suggested another fan be added."
"Custom Paint done by HPP (Red/Silver) **Car currently wrapped in Flat Black**"
...makes you wonder why they'd wrap a "custom painted" car.....
"dyno’d at Katech on their engine dyno at 14.7PSI to make 1000CHP"
"Powertrain:
Transmission: Stock
Differential: Stock"
1000CHP on a stock driveline? That should make for GREAT reliablility:wink:
Discussion Starter #6
Parasite reported.
"Powertrain:
Transmission: Stock
We wanted to wrap the vehicle to give it a different look for a the PRI trade show. We like the look, and have since stuck with it.
The Engine made 1000HP on the engine dyno at Katech. We have turned the car down to produce around 650ish at the moment.
The vehicle was meant to be a show car for various industry shows and to help transition our business model into the Modern Muscle era.
$1.. to be donated to this forum after the sale is completed. Car to be auctioned off for a veteran's charity after I take possession.
You DID say OBO.
1 - 8 of 8 Posts
