I have a stock 1982 305 in my car at the moment. I was just wondering if anyone knows about how much lift the stock valve train can take before causing valve, piston collision or other such problems :lol:
Any cam suggestions or ideas would be great!
Well, if two piston's meet, I want video cause that would look spectacular however it happened.
But for the valvetrain limits. I'm basing this off my 89 car, so it might be slightly different, and these are based on NEW hardware, as it would have come from the factory, not the old, worn out springs that are on there 20+ years later.
The stock L98 cam is about .430" lift with 1.5" rockers. The L69 of previous years is the same as the L98 cam, but in a flat tappet configuration.
I would say that when factory new, the stock valve train could handle no HIGHER than .450" lift, and asking it to rev past 5500rpm consistently would be a bad idea.
So add several decades and the worn out springs are probably not safe past 5000rpm, and would barely tolerate .430 or more.
Hope that helps a bit.
I have an LT1 in my car now, and I have a set of alu. heads sitting on a shelf with springs good to .650" lift, even though the cam is only going to run .560 or so.
