1 - 20 of 33 Posts
Vendor
Camaro Footwell LED Kit! RGB Multicolor & Single color options! Control w/Smartphone!
Looking to add a fresh look to your Camaro's interior? Footwell LEDs are the way to do it! By adding bright LED strips under your dash, you can add a lot to the look of your vehicle.
Diode Dynamics has been producing and designing easy-to-install LED kits for nearly a decade, and this kit is no exception. We have designed new LED strips to be used in this kit, which are highly flexible, IP67 waterproof, and long-lasting. This kit also uses our RGB Multicolor products, which are controlled by the included remote! You can change the color to fit your mood.
Customer Submitted Photos:
Included in the kit:
  • 2 (two) 30-5050 SMD Strips (flexible and IP67 waterproof)
  • Wiring harness for easy installation
  • 2 (two) quick-splices for installation
  • LED Toggle switch in your choice of LED color
  • RGB Controller Box with RF sensor and 4 outputs
  • Remote Control (choose Standard or upgrade to Bluetooth or WiFi)
  • 4 (four) zip-ties and 3M outdoor adhesive pads for mounting strips
  • 3-year Diode Dynamics hassle-free limited warranty
  • 30-day satisfaction guarantee
Also included with rear footwell option:
  • 2 (two) additional 30-5050 SMD Strips (flexible and waterproof)
  • 2 (two) 3-meter (ten-foot) extension wires
  • Additional zip-ties and adhesive pads
Any questions email us at [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks!
Nick C.
Vendor
Discussion Starter #7
Looking at some point / time, doing a floor light in blue, to match my ambient lighting..
LUV to do the rings if they can be doubled up (side-by-side) w/my RS tube ones ?
The footwell kit can be used in conjunction with our RGB cupholder inserts, using the same remote. It can be changed to any color, and customized to match the OEM color closely :thumbsup:
Nick C.
Getting plans in order ... do the instructions provide how to hook into the doors so they come on when the doors open? or are these only full time on? Thanks.
Vendor
Discussion Starter #12
Our basic instructions don't provide a method on tapping into the door or map lighting, but it can be done.
Several DIY threads have been posted for the 5th Gen Camaro on how to install them to achieve that effect.
It's a little more complicated than the basic install, but some prefer the OEM "auto" dimming
Nick C.
Nick C.
So with the basic install, the lights are on full time when the car is on?
I noticed you have the RGB halos but do you have any single color or can you custom fabricate perhaps?
1 - 20 of 33 Posts
