1 - 5 of 5 Posts
ユキヒョウ
Cerwin Vega 2 channel AB amplifier, Model HED 300.2. I bought it for a project and sold the car, so it never got installed. It also comes with the bass/gain remote, it's in a plastic bag with other extras, ie fuses speaker level connector etc........$ 80 shipped...lower 48.
Power Specifications - Full Range Channels RMS Power @ 4 ohms 40 watts x 2 channels RMS Power @ 2 ohms 75 watts x 2 channels RMS Power @ 1 ohm Not Stable Bridged RMS Power 150 watts x 1 channel Peak Power Output 300 watts x 1 channel
Amplifier Specifications Amplifier Class AB Number of Channels 2 Total Peak Power Output 300 watts Total RMS Power Output 150 watts Maximum Input Gauge Size 8 AWG Minimum Impedance Unbridged 2 ohms Minimum Impedance Bridged 4 ohms THD at Rated RMS Power 0.08% Speaker Level Inputs Yes Preamp Outputs 1 pair Built-in Crossover Low-pass (LP)
High-pass (HP)
Full (AP) High-Pass Crossover Frequency 50 - 250 Hz Low-Pass Crossover Frequency 50 - 250 Hz Subsonic Filter N/A Signal-to-Noise Ratio 108 dB Channel Separation N/A Bass Boost 0 - 12 dB Bass/Gain Remote Optional (Accessory required and sold separately) Fan Cooled Yes Fuse Rating 15A x 2
ユキヒョウ
You sold your Camaro.. :eek: .. :(
No, no, no :no: ....it was meant for a project car....Couldn't find any easy access for the power line thru the firewall, (without drilling) so I scrapped the idea of adding a sub....just been sitting in the closet and figure I'd try and sell it and the sub so someone can get some use out of it.
1 - 5 of 5 Posts
