1 - 17 of 17 Posts
Supporting Vendor
Chevrolet Camaro License Plate LEDs
License plate bulbs are used to illuminate the rear license plate on your Camaro. From the factory, the bulbs are incandescent, lighting up in a yellowish color.
Newer luxury cars use LED modules to illuminate the license plate with modern, cool white light. By changing your license plate bulbs to LED, you can easily add this luxury look to your Camaro!
The installation is 100% plug-and-play, just replace your factory bulb.
With low price and easy install, this is one of the best, easiest modifications you can do to improve how your Camaro looks at night.
Brightness:
Diode Dynamics offers several LED replacement options so you can choose the light output that fits you best. These options are listed by the design and the lumen output of each model:
SMD2: Slightly higher brightness than OEM bulbs. (24 lumens)
HP3: Much brighter than OEM bulbs. These are bright! (56 lumens)
HP5: Nearly triple the brightness of stock OEM bulbs! (92 lumens)
Bulb Design
SMD2: Compact design, with two 5050-size Epistar SMD chips, driven at high power for maximum effective brightness. Outputs at 180 degrees.
HP3: One high-power SMD under a diffusing lens for truly even output (no hotspots). Constant current design and air-cooled base for superior reliability. Features dual contact pins and nonpolar function for easy installation.
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS (to fit your Camaro).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
License Plate LEDs for 2010-2017 Chevrolet Camaro (pair)
(6000K HP5 Cool White Shown)
194 LED Bulb Models
If you have any questions, please don't hesitate to post, PM, or Email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Supporting Vendor
Discussion Starter · #7 ·
Supporting Vendor
Discussion Starter · #9 ·
Our Memorial Day sale starts NOW! Today through Friday, 6/4/2021, save 15% on all LED upgrades, including our
Interior LED Bulbs
by entering coupon code "USA15" at checkout!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 6/4/2021. Cannot be combined with other coupon codes.
Supporting Vendor
Discussion Starter · #10 ·
Our July 4th sale starts NOW! Today through Thursday, 7/8/2021, save 15% on all LED upgrades, including our including our License Plate Bulbs by entering coupon code "JULY4" at checkout!
Plus, all orders over $300 will receive a free Diode hat!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Thursday, 7/8/2021. Cannot be combined with other coupon codes.
Supporting Vendor
Discussion Starter · #11 ·
LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 7/8/2021, you can use coupon code "JULY4" at checkout for 15% off your entire order of lighting upgrades, including our License Plate Bulbs!!! Don't wait, this sale ends TONIGHT!
John C.
Diode Dynamics
Supporting Vendor
Discussion Starter · #12 ·
Now's the time to upgrade your ride! Our Labor Day Sale is going on NOW! Save 15% sitewide, including our License Plate LEDs, by entering coupon code "LABOR" at checkout! And, all orders over $300 will receive a free Diode flag tee! Sale ends Friday, 9/10/2021.
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 9/10/2021.
Sale excludes preorders.
Supporting Vendor
Discussion Starter · #14 ·
Don't miss your chance to save 15% off your entire order of lighting upgrades, including our License Plate LEDs, with coupon code "LABOR" at checkout! Plus, get a free Diode flag tee when you spend $300! HURRY, this sale ends TONIGHT!
John C.
Diode Dynamics
Supporting Vendor
Discussion Starter · #15 ·
Now's the time to upgrade your ride! Our Black Friday Sale is going on NOW! Save 15% sitewide, including our License Plate LEDs, by entering coupon code "BF21" at checkout! And, all orders over $500 will receive a free Diode Dynamics long sleeve shirt! Sale ends Tuesday, 11/30/2021.
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Tuesday 11/30/21.
Supporting Vendor
Discussion Starter · #16 ·
Don't miss your chance to save 15% off your entire order of lighting upgrades, including our License Plate LEDs, with coupon code "BF21" at checkout! Plus, get a free Diode Stage Series long sleeve shirt when you spend $500! HURRY, this sale ends TONIGHT!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST | Tuesday, 11/30/2021.
Supporting Vendor
Discussion Starter · #17 ·
Diode Dynamics’ Memorial Day Sale is going on NOW through Friday, 6/3.
Get 15% off all LED lighting upgrades with code "USA22" during checkout!
Plus, all orders over $300, will receive FREE shipping.
Click HERE to shop Diode Dynamics LED Lighting products!
Note: Products on pre-order (Elite Series Fog Lamps) are excluded from this sale.
1 - 17 of 17 Posts
