This is a comprehensive list of videos and guides for repairs, maintenance, replacements. updates and modifications.
Please advise of any broken links.
Battery https://youtu.be/URaxP0FuaL8
Blend Door - In Vehicle Method https://youtu.be/K0jajaoc-ro
Bosch EDC16 ECU - How To Take Apart https://youtu.be/UR-8CLIPv3c
Cabin Ait Filter https://youtu.be/-xJ1BIJZ7A4
Change Engine Oil https://youtu.be/qdk7Z98_x4A
Check Engine Fluid Levels https://youtu.be/H4bJK40M2Ow
Cooling Fan Assembly https://youtu.be/tspdfH1gXVs
Differential Fluid Replace https://youtu.be/WwejWy6qIOM
Door Panel https://youtu.be/VnDybfAMgR4
Door Speaker https://youtu.be/_6lL7-2ODLo
Door Tweeter https://youtu.be/nqKXm0TwxZ4
Engine Air Filter https://youtu.be/iH_P8fpSE6Q
Fog Light Assemblies https://youtu.be/7omvx3TVLw4
Fog Light Bezels https://youtu.be/fdIGL06yOXY
Front Brakes https://youtu.be/GlDiHibH1-Y
Front Bumper Cover https://youtu.be/9KvU_qxpLcM
Front LCA - Forward https://youtu.be/9YNdxXzuxQQ
Front LCA - Rearward https://youtu.be/dZb9lihkVL8
Front Lower Grille https://youtu.be/V9UJgW_7SKA
Front Side Marker Bulbs https://youtu.be/dD86NEa00LI
Front Struts https://youtu.be/jXuoPUC7xMw
Front Swaybar Links https://youtu.be/vXK2bNuSdhU
Front Upper Grille https://youtu.be/b3cPnnr0BFQ
Front Wheel Bearings https://youtu.be/b1rOV6FjsKU
Headlamp Assemblies https://youtu.be/Sp96S2YUWmY
Hood Struts https://youtu.be/qFK8jMShXjw
Horns https://youtu.be/WBQScebGpAo
Iner Tail Light Housing https://youtu.be/aOL9z_BiwJk
Inner Tail Light Bezel https://youtu.be/dM29SjXwJPw
MAF Sensor https://youtu.be/1xo4lBsERK0
Manual Transmssion Fluid https://youtu.be/d6k957Nm5iw
Melling Timing Kit for GM 3.6L Installation Tips https://youtu.be/1SC8Jy9NOJk
Oil Minder Reset https://youtu.be/qcgkAcOAqhQ
Outer Tail Light Bezel https://youtu.be/uns0CyCr7x0
Outer Tail Light Housing https://youtu.be/B0qz9U7W1dU
Power Mirror Switch/Adjuster https://youtu.be/l-9xsJY-P1k
Power Window Switch https://youtu.be/9EpgMxiIzew
Purge Soleniod https://youtu.be/SlSr87xLavs
Radiator Fan Assembly https://youtu.be/tspdfH1gXVs
Radiator Replacement https://youtu.be/5dAhBjwGoQo
Raise & Support Vehicle - Lift https://youtu.be/vdroW_Wpkf8
Rear Brakes https://youtu.be/YDuCnMM5E8o
Rear CV Axles https://youtu.be/L1OlaJlhMGo
Rear LCA https://youtu.be/YLL7KPZl9qY
Rear Struts https://youtu.be/Toc0VPgg2rM
Rear Swaybar Links https://youtu.be/10wtHcLf8O4
Serpentine Belt https://youtu.be/Gy-jQZ7IY-8
Serpentine Belt Tensioner https://youtu.be/6Z3Y1iqagCU
Side View Mirrors https://youtu.be/uhjXBenHEMI
Tail Light Bulbs https://youtu.be/CWFKGRupOPU
Timing Chain Failure, Reason & Fix https://youtu.be/7YaZLY91HD0
Trunk Cargo Net https://youtu.be/hCOltN4EFLM
Trunk Release Button https://youtu.be/uaGuTDnni6k
Upper Intake Tube https://youtu.be/Iog0GbxUdtY
Washer Pump https://youtu.be/UBOdxAIdV9k
Washer Reservoir https://youtu.be/dK77VR59vxk
Wheel Speed Sensor https://youtu.be/3Bo0XtgBWFQ
Modifications:
2012+ Steering Wheel Swap https://youtu.be/DUJ-910_FoQ
Black Decale Kit https://youtu.be/DiaFTy4tFpo
Moser Live Axle Conversion https://youtu.be/Vu1_0qYOlRk
PCV Valve Update (10-12) https://youtu.be/wCV1KMrX4uI
Reluctor Wheel Set Screw Update https://youtu.be/w4mbn6GRpKc
Strut Tower Brace https://youtu.be/faY6uNgGvls
2010-2015 (GEN5) CAMARO V6 ENTHUSIASTS
Contains Albums, Guides, and Files for repairs, mods, and specifications.
You'll need to be logged into Facebook.
Modifications:
