Converting DRL'S To fog lights
2K views 0 replies 1 participant last post by  sk8erdad
#1 · (Edited)
I purchased the wiring harness on E-Bay to convert my DRL's to fog lights. My problem is that when I have my E-brake on only the passenger side light works. When driving with my daytime running lights they both work. When I turn my headlights on only the passenger side works again. Has anyone else experienced this. I just have no idea as to what to check. Other than taking the harness off and going back to the original DRL's. I'd appreciate some advice as to what I should do
FYI- I figured out my problem. I pulled the harness back out and found that one of the pins were bent and not in the hole. Straightened it out quite carefully so it wouldn't break and bingo both fogs are working with lights on and off.
