1 - 14 of 14 Posts
What oil temps are you seeing while cruising at highway speeds with outside temps in the 50-70 degree range?
Our 2014 SS L99 runs 203 degree coolant temps and 223-225 degree oil temps while cruising.
Search didn't turn up much. Thanks.
My V6 runs about the same. Coolant temp spiked up to about 215 in stop and go driving, but the gauge stayed under the 1/2 mark...
Check mine out after reading this post and was surprised to find them almost exact as yours......so I guess that norm.
On a quick run today ... I thought I looked and saw about 210 ... it was only about 10 miles when I looked, so not sure how helpful that is (or how close I looked)
I just double checked my oil temps last night on the ride home.
Outside temp: 90F
Stop and Go Traffic: 225F - 235F
Cruising 70-80 mph: 210F - 215F
I will check the coolant temps tonight, as the outside temp will be about the same.
I looked at mine again on a little longer drive ... was just a little bit above the 210 line, so I'm guessing 215ish
Discussion Starter #11
Outside temp: 90F
Hmm.....some cars cruising oil temps running 10-15 degrees cooler than others.
Our outside temp has not gone above 70F.
Thanks guys:thumbsup:
Outside temp last night was 87F-89F.
Coolant temps:
Stop and Go: 195F - 205F (AC Off)
Cruising 70-80mph: 180F - 185F Mostly steady at 180F (AC On)
All my temps were measured using the DIC.
Oil Temperature Question
Hi Guys,
It is cold out but I noticed that my oil temp won't go above 84°C (183.2° F) It actually bounces between 84°C and 83°C (183.2° F and 181.40° F) Is this normal? It is not falling in between the yellow lines as it is supposed to.
2SSRS L99 coolant 198 and oil temp about 210 while cruising. I never go WOT with oil temp below 200. Personal preference but I have 93K miles so far, and it works.
1 - 14 of 14 Posts
