1 - 11 of 11 Posts
I just thought it might be fun to start a friendly debate on what peoples different opinions of a "Stock" car are and what their reasoning is. Now I know some people are very passionate about this so let's try to keep it fun and not make anything personal!
I'm personally kind of on the fence on a few things. I think things like air filters that would be replaced due to maintenance anyhow do not void a car of it's "Stock" classification. So here is a short list of parts that I feel can be "replaced" and still allow the car to remain classified as "stock"
1. Air filters (filter only, not an entire CAI kit).
2. Tires - as long as they mount onto the wheels that came with the car.
3. Plug wires - they would be replaced later due to maintenance anyhow.
4. Spark Plugs - again a maintenance item.
5. Fluids - Engine oil, Transmission fluid, brake fluid, differential fluid, etc...
6. Brake Pads - as long as they fit into the OEM calipers
7. Brake Rotors - again as long as they are designed as a direct replacement with no other supporting modifications required.
8. Muffler(s) - muffler only, not the entire CAT back.
9. Battery(ies) - as long as it's designed as a direct replacement in the stock location.
10. One I'm on the fence with is Tuning. On one hand I feel that tuning only maximizes the "stock" potential of the engine since OEM's need to worry about warranties and are therefore going to be a little more conservative in their tunes. But I can see the other side of the coin too where some people feel that a tune disqualifies a car as "Stock".
So let's hear what some other peoples ideas are.
General wear and tear items such as fluids, filters, and tires. Tires are tricky as a drag radial would not be stock. So an equivalent replacement would be the more detailed definition. Same with brakes as there are plenty of upgrades such as Hawk or EBC.
Mufflers are not wear items. Tuning is not a wear item.
It's very simple to define stock, IMO.
There is also a "Showroom Stock" which would be identical replacements such as Delco parts and the same tires.
Yes I feel that "Showroom Stock" is a little easier to define and set boundaries for that the singular term "stock". Adding the term "showroom" in that title pretty much defines for you.
when I think of "stock" I ONLY think of drivetrain. But when a warranty company is concerned, they don't like ANY aftermarket parts. Not that using non-ac delco plugs is gonna upset anyone, but if you read your owners manual, it does tell you to use GM approved fluids, ac delco parts etc...blah blah blah.
There is a difference, though (at least in my definition). "Showroom Stock" is 100% identical to how it was delivered from GM (not from the dealer, mind you, as dealers can put all sorts of things on and sell as new). Showroom Stock may have had a new set of tires or a new air filter put on at some time in the vehicle's life, but those items will be the direct GM replacement part.
"Stock" is factory equivalent. You are not getting Z rated tires to replace all-seasons, and you're not going to change the heat range of the spark plugs. Yes, you can use a different supplier (NGK plugs versus Delco, or Goodyear's versus Pirelli), but the parts will be equivalent.
Any deviation from that will result in a modified vehicle. Any form of computer programing (other than a GM service update) will also result in a modified vehicle (such as Tim was razzed when he posted the fastest "stock" A6 time ;) )
Discussion Starter #7
I guess you'll always be stuck with your shark fin then if you want to remain "stock":D:p Just razzing you a little demonspeed since your avatar description says "shakfin hater"!!
That's why I think this is fun though, just to see what everyones opinions are. No right or wrong answers, just fun discussions.
Yup, not saying I'm right or wrong :)
And I will pray they remove the fin in the future :D
I generally concur with demonspeed's assessment. I appreciate modded cars as well as factory stock cars. I do believe it is MUCH harder to restore a car to factory stock status though.
Supporter of common sense
Well put
+1
1 - 11 of 11 Posts
