2010-2013 & 2012-2015 ZL1 RS Chevrolet Camaro RS Halo Multicolor LED Boards
The only RGBW Halo LED Board Replacements made in USA!
The factory-equipped RS halo DRLs are an iconic feature on the 5th Gen RS Camaro. They are illuminated by a set of circuit boards, which contain white LEDs.
Diode Dynamics' engineering team has designed an OEM-quality LED board replacement to upgrade the single-color factory units with the newest RGBW LED components!
RGBW functionality allows for full multicolor control while also retaining a brilliant white OEM color temperature.
By using RGBW components rather than standard RGB, this product creates a true white color temperature vs. the traditional method of combining all RGB colors together to make "white".
This is an OEM-grade solution, with exact laser-scanned fitment, and perfect alignment of the new LED units. Simply remove the factory boards, and replace them with the upgraded Diode Dynamics RGBW units.
Each order includes two sets of LED boards and drivers, one for each headlight on your 2010-2013 / 2012-2015 ZL1 5th Gen RS Camaro
To drive the high-power LEDs safely, a new constant-current, waterproof, inductive driver is included for each set. You will also need an RGBW controller with this kit. Controllers can usually be powered by any standard 12V source. We recommend connecting to the parking light signal, so this module lights up when the parking lights or headlights are on. You can set the LEDs to the white setting for everyday use.
Professional installation is strongly recommended, as the factory headlights must be opened up to replace the factory LED panels. Wiring instructions are included to identify the wire colors required to power your controller.
All Diode Dynamics products are backed by a 3-year replacement warranty.
Professional installation is strongly recommended, checkout our dealer locator tool:
Find a Diode Dynamics Dealer
Made in USA by Diode Dynamics Manufacturing.
Diode Dynamics: 2010-2013 Chevrolet Camaro RS RGBW Multicolor LED Boards
Diode Dynamics: 2012-2015 ZL1 Chevrolet Camaro RS RGBW Multicolor LED Boards
RGBW board replacements and demon eyes shown -Retroshop Installation
*Compatible with 5th Gen ZL1 Camaro housings
If you have any questions, please don't hesitate to post, PM, email [email protected] or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Universal RGBW™ Demon Eyes installed (Optional, but recommended!)
