From the press kit:
Vehicle Type: Two-door, four-passenger rear-wheel drive sport coupe
Wheelbase (in / mm): 110.5 / 2806
Length (in / mm): 186.2 / 4730
Width (in / mm): 79.6 / 2022
Height (in / mm): 53 / 1344
Track (in / mm): 63.8 / 1620 front - 63.3 / 1607 rear
Engine: 6.0L V-8 LS-2. 400 HP / 298 KW. with Active Fuel Management (tm)
Transmission: Six-speed manual T56
Suspension: Four-wheel independent: MacPherson strut front, multilink rear. Progressive rate coil springs, gas-pressurized dampers
Brakes: Four-wheel disc. 14" rotors with four-piston calipers
Wheels: Cast Aluminum. 21" front, 22" rear.
Tires: 275/30R21 front. 305/30R22 rear.
