1 - 20 of 36 Posts
Sooooo, I am rebuilding my garage.
It is going to be 24' wide, West to East gables.
It is going to be 20' deep, North to South overhangs.
Nothing out of the ordinary.
I am actually having a contractor of Home Depot's build it.
They are called Tuff Shed(sp?)
This is not set in stone, but the best option at this point.
Now, I need some ideas for the interior and would like to see
pics of your garages.
I am contemplating using kitchen cabinets for storage, but MDF
in High hunidity is not a good idea.
I already have my HObart MIG and I am about to buy a
Quincy Compressor and Dryer and a Scat Blast Media blaster.
We just bought stackable Maytag, I think, front loading washer
and dryers to be installed IN the garae in their own room IN
the garage.
There will be one large 16' door in the middle of the North side.
I plan on installing my JD2 Model 2 bender in the middle of the room
so I have plenty of room to slin pipe.
I want a LARGE rolling welding/fabrication table.
I need music and maybe some visual stmulation. No fishtanks!
Any insights on floor coatings would be great as well!
These are just ideas and I am looking for yours!
Dark Side Moderator
Go all out, do this:
Is there going to be enough room for a lift or have you considered digging and pouring concrete for a service pit?
I have been renovating my garage ,getting ready for the new Camaro. It's
24'x24' with 8' ceilling. So far I have 7/16" OSB on the ceilling and Bead Board on the walls. I thouhgt the Bead Board would be more durable than Drywall plus no tape no mud. The next thing will be the classic black/white checker floor. As far as tools and storage, all that stuff is in the 30'x40' pole barn.:bowtie_gold:
we've actually had kitchen cabinets in our attached garage for the past few years and no problems... and you know n'awlins has high humidity. :lol: here's a crummy pic, but it shows the cabinets. i think you'd be okay.
we are also looking into doing a coating on our floor. supposedly home depot has the system for a whole lot cheaper than U-Coat It.
I'm a garage snob, my wife hates that I'd rather upgrade in there than the garage. Include some type of garage floor coating. Be wary of the stuff in the kits from HD & Lowes, do your research. As another suggested, beadboard or paneling at the lower level will be more durable against scuffs and dents than drywall. I went to a cabinet store and bought some leftover/remnant/scratch & dent stuff and hung them. Got alot of stuff for about $300. Nothing too fancy but they're great for the garage, plain white, great for holding all my detailing and hand tools, etc. Good luck!
In a car mag I read awhile back, the whole floor was a checkered flag...it was pretty sick.
I'm too embarrased to post pics of my garage...it's wood and dirt. lol
My garage has two cars a motorcycle two bicycles and a whole lot of sport stuff. It is not the nicest room
the garage.
As for Floor Coating listen I live in Texas and we have humidity up here in DFDUBYA as well lol I also have Family in Austin and those members have used the same garage floor epoxy as well.
My Neighbor puts this stuff on for a living so thats how I know of it so well lol
im basically going to paste and copy his e-mail from his work to you on here.
First off keep in mind Garage floor coatings fail for a number of reasons. First, the floor is usually not clean enough to receive a coating. Years of grime have to be removed using all solvents and cleaners you may have used on this flooring. These are sold at paint stores, hardware stores, home centers like home depot/Lowes and industrial supply houses. If the floor is really filthy, consider pressure washing. Rent a machine that produces at least 1200 to 2000 psi. Also buy some grease-cutting detergent at the rental store. Along similar lines, you might consider a steam cleaner if a pressure washer is unavailable they work the same :thumbsup:
Another problem is moisture vapor. Moisture vapor from the ground works from below to loosen the coating's bond with the concrete. In the case of alkyd paints (also called oil-based paints), the moisture will react with the alkaline materials in the concrete and form a soap. This process is called saponification. The soap loosens the paint's bond with the concrete. Never use alkyd or modified alkyd paints on concrete, no matter what the clerk at the hardware store says.
And of course a car's tires are hot when it pulls into the garage. In the summer, the tires may be even too hot to touch. The heat can actually melt the paint and–combined with the pressure the car applies on the tires–even peel the paint. This is known, appropriately, as hot-tire pickup.
Important after you seal a floor give it time to dry I have always said give it a good 5 days or so before putting anything heavy like a car on it !!!!!!!! ITs cures to walk on in half a day.
Fortunately, there are ways to beat all these problems that are listed above .
The cool thing is Paint manufacturers have finally recognized these problems and have come to the rescue with new formulations. But a word of advice: If your garage floor sees heavy water leakage, if it's badly cracked or if it's damp and slimy all summer, don't apply any coating. In those cases, you're better off simply keeping it as clean as you can and then calling it quits.
As for what to use I have it in my Garage my Uncle has it in his garage in whichita Falls and my cousin has it in his Garage in Austin !!!!!!!!
Its called Epoxy Shield garage floor paint. It's a waterborne coating consisting of epoxy and acrylic resins with color chips that you sprinkle over it while the coating is wet. Its manufacturer says it is specifically formulated to withstand hot-tire pickup, moisture vapor and attack by solvents and chemicals that drip from a car or come in on the car's tires. It comes as a kit that consists of a cleaner-degreaser, two paint components that you mix together and nonskid color chips. First clean and degrease the floor, then mix the two-part coating together and roll it on. And finish up by broadcasting the nonskid chips onto the coating while it is still wet. The manufacturer says you can walk on the surface in 4 hours and drive on it after seven days when it is fully cured. The kit costs about $60 at home centers or you can contact
contact Epoxi Tech, 888-683-5667. or lol
http://paint-and-supplies.hardwarestore.com/49-350-garage-floor-paint/epoxy-shield-garage-floor-coating-101866.aspx
I give it :thumbsup::thumbsup::thumbsup: its on all of my Families floors and we have thrown everything at our garage floors even Sparks from a cutting torch lol
Good luck bro :thumbsup:
Discussion Starter #10
Thanks guys and gals.
Daytona, that funny as that is the stuff that I was looking at.
I actually have done a ton of research on floors and everything your buddy says is 100% correct.
I will be adding two feet to the slap east and west and then powerwashing, doin a detergant scruba nd then an acid wash of the concrete to prepare it for the coating.
Now guys (JINX) with that said, and I should have noted this earlier, I want a NICE garage, but my wife and I are afraid once we get the house done we may want to stay here a few more years. Quite the pickle we have.
Why move from a house and garage that we just sunk $30,000 into and move to a house that we know nothing about!
ANyways, I found a local school district that has some very nice upper cabinets on auction.
I am going to go look at them next week. They look like solid wood, so the humidity issue just might resolve itsself.
No pit ot lift in this one, but the next one definitly a lift at the least.
Thanks trott, great idea!
Selena, thanks. BTW, is that you in your avatar. NICE!
I am having my father make up some cad drawings hopefully soon!
Hey man he does it for a living and I as well as family members have this stuff on our garage floors :thumbsup: The only thing I have known to make garage flooring come up is a car parking on it and backing off and it rolling off onto the tire.
Cleaning/prepping the surface is the most important part then let it cure.
I have Grey on my floor. I need to take some pictures of my garage and post them and let you see. The little flakes for slipping are not required to use....I didnt use them in my floor I know how to walk on my Feet ty lol
I thought if water was on my floor you are going to slip either way if its there or not.
But yeah this stuff is the $hit !!!!!!!!!!!!!!! I recommend it and so does he :thumbsup:
the garage.
If you decide against going with Home Depot, let me know. I can design you a garage to that size and write the bid and specs for it and it would be code legal too.
Let me know if you're interested.
picture it without my old z this is my garage on the house three stall...no lift kinda like the showroom.i got pics of the barn with my lift ill post
a little bathroom is a must imo in a workable garage. you know it will be a pita to be all greasy and have to number 2, have to run all the way inside and do your business....
My bathroom in my garage is walking into a corner and pissing making a sloppy mud pit for the neighbors cat to drink from....ewww. what?
Discussion Starter #19
If you decide against going with Home Depot, let me know. I can design you a garage to that size and write the bid and specs for it and it would be code legal too. Let me know if you're interested.
I really appreciate it, but my father is a VERY good architect and engineer, it's more that I do not want to build it. I want it done NOW!!! Know what I mean?
I'd also suggest (if you haven't already thought of it)...to build a separate room (if you have the space) for your air compressor...to keep the noise down.
There are alot of people that do that, but it is not needed if you buy a quality air compressor. The Quincy I am buying is VERY quiet and one of the best on the market.
and think about comfort have stools for your benches, maybe a sitting area with a rug, tv, you want internet access, even a bathroom if theres room
Ummm NO. I am thinking about a urinal and a sink and that is about it. I do not plan on being here much longer, but I want some WOW factor when a guy walks in there. :lol: This garage will be USED for fabrication, you know man's stuff. No lounging here, well maybe a few chairs.....tryig to find some restaurant booths!
Thanks guys and Selena!
Discussion Starter #20
I got the roof tore off yesterday, so I am that much closer:
OK no toilet going in the garage.
I only have 1 1/2" drain back to the sewer and I am not digging it up to add 2 1/2" for the toilet.
SO I am going to have to do the doo inside!
1 - 20 of 36 Posts
